Newbie question concerning homelink (but not about programming)
Discussion in 'Gen 3 Prius Main Forum' started by SuperGLS, Oct 26, 2015.
  1. SuperGLS
    SuperGLS Member
    200
    52
    Washington DC
    I've had my Prius for a couple of years now, but have never had a house with a garage until this weekend.
    I've got the homelink button all set up to open and close the garage door.
    Here's the question.
    My wife also has a Prius. If I program her homelink button as well, does that mean that we don't need to carry the garage door remote in either car? I mean, is the point of homelink so that you don't have to buy multiple remotes or just so that you can press the button and keep the remote in the glovebox?
    Thanks in advance!
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Yep, the point of it is so you don't need the remote that came with the opener in the car. The Homelink system is now the remote in a sense. You can leave the remote in the glove box if one chooses, it will not affect anything, but there isn't a need to once you have the opener programmed to a button in Homelink.
    My Homelink uses two buttons for 2 separate garage doors and I don't carry either remote in the vehicle.
    SuperGLS likes this.
  3. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    Our Prius is set to open 2 doors and we don't carry either remote. As long as both cars open the door, no reason to carry the remote. Obviously we carry a key to the house in case the openers fail. :)
  4. SuperGLS
    SuperGLS Member
    200
    52
    Washington DC
    Thanks guys. I figured that was the case, but wanted to be sure.
    And I'm glad I thought about this before paying for another remote. PC saves people money everyday.
    el Crucero likes this.
  5. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
  6. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    I put my remote in a safe place with the battery out, so if I get another car with home link, syncing it up will be no problem- as long as I remember where that safe place is....
  7. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    That reminds me, I need to take the battery out too. Thanks.
  8. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    A little hint for those remotes and flashlights you hardly ever use but need to work when you need them. Use the "Energizer Lithium" cells if the devices use AAA, AA, or 9V size. They won't leak -ever-, and have an advertised shelf life of 11 years. I have some that are almost 20 years old and still work just fine. Expensive, but very reliable.
