Newbie question re: 2017 v-4 heated mirrors & battery
Discussion in 'Prius v Main Forum' started by Agusto2017, Nov 22, 2017.
  1. Agusto2017
    Agusto2017 Junior Member
    42
    Waterville, Ohio
    2017 Prius v wagon
    Her name is Hazel. Better calling it that instead of Grandma Green. (Sea Glass Pearl).
    Her sticker reads "heated mirrors". How do they work? Am I missing a switch in the car. I couldn't find anything in the manual.
    Next, I've purchased a seat cover for my rear seats since I have a dog. From what I understand, my battery is in the rear compartment, near my spare tire. Does this vent somewhere that my seat cover will interfere with? I've read some batteries are under the rear seats, mine is not.
    Thanks for any help!
  2. Frankemtp
    Frankemtp Junior Member
    16
    Chicago, IL
    Four Touring
    When you turn on the rear defroster, the mirrors heat up. They work quite well. Just remember not to touch the heated mirror.
    Agusto2017 likes this.
  3. Prodigyplace
    12,712
    11,848
    Central Virginia
    Welcome!
    I am not sure on the Prius v but on mine the heated mirrors turn on with the rear defroster. My button shows both the rear window and mirrors.
    Yours may be similar.
    52,824
    mine turn on the the heated seats.
    as for the rear seat cover, make sure it doesn't block the hybrid battery cooling intake grille. not sure where that is on the v.
    Prodigyplace likes this.
  5. Agusto2017
    42
    Waterville, Ohio
    2017 Prius v wagon
    Thank you both! I'll look at the defrost button in the morn.
  6. Prodigyplace
    12,712
    11,848
    Central Virginia
    Bisco’s reply may be more accurate since his car is more similar to yours than mine is. I do not have heated seats either.
  7. Agusto2017
    42
    Waterville, Ohio
    2017 Prius v wagon
    Yikes. Heated seats = heated mirrors? I hope that's not the case for the v's. My seat gets too warm for these buns, at least in November. Maybe I'll enjoy that heat in January!
  8. bisco
    52,824
    does seem odd, doesn't it? now i have to look at the manual.:oops:
    Agusto2017 and Prodigyplace like this.
  9. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    The hybrid battery intake vent is under the rear right side passenger seat on my 2016 Prius v Three. Yours is probably in a similar location...
    Prodigyplace and Agusto2017 like this.
  10. Agusto2017
    42
    Waterville, Ohio
    2017 Prius v wagon
    Thank you! I'll check in the morning.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The battery vent on the v is under the passenger rear seat.
    The rear window defogger is also the outside mirror defogger.
    "Defogging the rear window and outside rear view mirrors
    Defoggers are used to defog the rear window and to remove raindrops, dew and frost from the outside rear view mirrors." page 368 https://www.toyota.com/t3Portal/document/om-s/OM47B23U/pdf/OM47B23U.pdf
    PearlV and Prodigyplace like this.
  12. Agusto2017
    42
    Waterville, Ohio
    2017 Prius v wagon
    Thanks Jimbo,
    So the vent is under the rear seat...my seat cover has a flap that fall down the front of the rear seat, almost hitting the floor. Will that interfere with ventilation?
  13. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Without being able to see it, I would fold the flap back under seat cover so it does not hang down on the passenger side.
  14. Agusto2017
    42
    Waterville, Ohio
    2017 Prius v wagon
    I fòund the little vent under the rear passenger seat! Thanks! Now I think I'll cut my seat cover on that side to allow ventilation. Thank you all. I appreciate your help!
    Sooner Al, bisco and Prodigyplace like this.
  15. Sooner Al
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    I check the vent occasionally just to make sure its not clogged with debris. I had to vacuum it once using a long extension on the vacuum hose.
  16. Norcal2
    Norcal2 Junior Member
    23
    Sacramento
    2015 Prius v wagon
    Ive noticed my drivers mirror does not clear as good as my passenger one does it takes a while has anyone else had that problem with thier drivers mirror defog not working as fast? Im going to take my laser temp reader out and double check both when its cold...
