Newbie questions: charging, EV mode, noises.....
Discussion in 'Prime Main Forum (2017-2022)' started by MarkOlin, Dec 24, 2019.
  1. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    Gurgling like "whrrrr" noise from the brake actuator when you press the brake pedal, (or when you first open the driver side door) is normal, but "grinding" noise you are describing sound abnormal. Wait for more knowledgeable brake experts like @Mendel Leisk to chime in.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Rust on the rotors:whistle:?
    Based on your avatar, you've got enough moisture around to create the rust;).
    If it goes away after a couple of brake applications, it's normal(y).
    jerrymildred likes this.
  3. jeminy9
    jeminy9 Junior Member
    16
    2020 Prius Prime
    Could it be ice or salt from the road getting on the rotors?, Also the Prius pedals seems to transmit lot more NVH from tires compared to my other cars.
  4. Matthew J Geinitz
    Matthew J Geinitz New Member
    Los Angeles
    Interesting question. I bought a mini adapter from a doctor that let's me use my prime level 1 charger with a 240v 6-20 plug. The problem I have is I charge outside and have a lock box. Since the level 1 charger that came with the prime is a straight plug I can not lock the box anymore. There is no room. If I bought a 1 foot 110 right angle extension cord at 14 gauge. Would it be short enough to not have a issue with 240v? I think the prime only pulls 16 amps. And 14 gauge is rated at 15. So with such a short run it should be ok right?
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Is the lock box metal? So any fire is contained? If so, go for it! (We just do not want to set fire to your house)
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    I'm almost positive that @Raytheeagle hit the nail on the head. If it's been raining or even in high humidity, the rotors will flash rust. When you first start out, the brake pads will scrub the rust when they engage. It often takes a couple stops to get it all. Happens to me almost every day here in the armpit of North America. Not just a Prime thing. Any hybrid that uses a similar braking system will do that. Actually, any car can be prone to it depending on what the rotors are made of. To verify it, do as Ray suggests and do a few stops to see if it goes away.
    Raytheeagle likes this.
  7. MarkOlin
    MarkOlin Member
    78
    39
    Buffalo, NY
    2020 Prius Prime
    I'm not so sure about that. I can drive the car to and from work and I notice the noise after my drive. Seems like I only notice it during EV mode at very low speeds, like -3mph while parking.
  8. Matthew J Geinitz
    Los Angeles
    Yes it is a metal box mounted to the outside wall. One side had a 110 outlet. The other the 240 6-20
  9. jerrymildred
    11,517
    14,152
    Tampa, FL
    Mine have always done that. Normal sound for Prius brakes. If they are squealing, that's not normal. But the rubbing sound is just one the many sounds this car makes. If you're convinced there's a problem, then you really should take it to a brake shop, preferably one familiar with hybrids.
  10. MarkOlin
    MarkOlin Member
    78
    39
    Buffalo, NY
    2020 Prius Prime
    Thanks, I was hoping to hear that this is normal. So, its not just my car
