Newbies - Let's See Some Pics!
Discussion in 'Newbie Forum' started by Husker4theSpurs, Jan 27, 2008.
  1. Steph1972
    Steph1972 Member
    65
    53
    St Adolphe D’Howard
    Four Touring
    Fantastic color
    Storm88000 likes this.
  2. southsidedakota
    southsidedakota Junior Member
    28
    22
  3. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    Glad you did! Welcome!
  4. JohnnyPR
    JohnnyPR Member
    96
    25
    Hinesville, GA
  5. clowndog
    clowndog Junior Member
    Michigan
  6. SeattleBebop1
    SeattleBebop1 Active Member
    163
    105
    Seattle
    Pre-lift w/factory tires, fresh off the transporter: Prius_front.jpeg Prius_side.jpeg
    Pri3C, Montgomery and Steph1972 like this.
  7. SeattleBebop1
    163
    105
    Seattle
    Post-lift with 20 oz Yeti for scale (7.3" clearance). Also, pics of the WeatherTech Stainless Steel License plate covers. I feel that the steel matches the silver on the Prime nicely (I also got steel valve stem caps.)
    Pri3C, Burna J and Steph1972 like this.
  8. prime grip
    prime grip Member
    115
    56
    SO CAL
    2021 PRIUS PRIME XLE. 5% ceramic tint. 5000 miles today. Fresh oil. ready to roll
    Pri3C likes this.
  9. prime grip
    prime grip Member
    115
    56
    SO CAL
    Montgomery, Burna J and SeattleBebop1 like this.
  10. prime grip
    prime grip Member
    115
    56
    SO CAL
  11. SeattleBebop1
    163
    105
    Seattle
    Four flats! Bad luck. :eek: To my surprise, I never got a flat in my '03 Prius during my six years of ownership, but I did indeed have the magic spare under the trunk mat warding off evil.
    I haven't yet been willing for the space hit in my Prime. I'd have to do the "tuck behind the passenger's seat" in mine, because I need the cargo space for my gear.
  12. prime grip
    prime grip Member
    115
    56
    SO CAL
    Yeah, 2 regular flats and 2 bad shredders in the same month. All different tires. But you know what, the car handled like a dream. 75 mph next to a k- rail in the car pool lane with a flat no problem, but getting it fixed... that was the problem. Now with my little insurance in the back. no problem.
  13. SeattleBebop1
    163
    105
    Seattle
    Next to a barrier? Terrifying! I'm glad to hear the car handles well though. I would prefer having a spare in my Prime, more than having that goop stuff. I've changed tires before, but I don't know about that goop.
  14. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    My goop is in a drawer in the garage. It helps make room for the real compressor and tire plugging tools. Then there's the spare tire in case of a blowout.
  15. prime grip
    prime grip Member
    115
    56
    SO CAL
    The goop is no good. I used it on my first flat. They can’t repair the tire with that stuff in it.
    Spare tire is the only way. It takes up space but it’s better then waiting on a tow to the Dealer, and then buying a new tire from them.
  16. SeattleBebop1
    163
    105
    Seattle
    Ugh, this is making me wary of the goop!! So it can ruin your tire that may have otherwise been salvageable (e.g., just a nail through the tread), like mess up the TPMS?!! Shame on Toyota to put that in our cars. (I do already carry my own mini "Slime" compressor, cheap I guess but it gets the job done and fits in the rear passenger compartment.)
    So what do y'all do for your spare tires? I think I'm sold that I need to carry a spare, esp. since I do some very rural backpacks every year. (I shouldn't expect my streak of lucky tires with the '03 to continue.) Did you buy a spare standard Prime wheel, then mount a full size tire on it?
    I am running 215/70R15 Generals on my lifted car, so I'm thinking I would just get another same-sized General as my spare. I see @Salamander_King keeps his tucked behind the passenger seat (when I'm backpacking, I would be using all the cargo space for that gear and no room for tire there.)
    At least Toyota gives us a jack and wrench.
    Salamander_King likes this.
  17. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    My full-size spare is an old OEM tire off my previously owned Gen3 that had a non-repairable flat on one tire early on which made me to buy a set of two new tires for the axis leaving one fairly new but used tire. The rim is aftermarket cheap steely. The total cost including the cover you saw on my storage set-up was less than $80 (tire $0, rim ~$50, mount and balance ~$15, cover ~$15).
    #2737 Salamander_King, Mar 3, 2021
    SeattleBebop1 likes this.
  18. SeattleBebop1
    163
    105
    Seattle
    Hmm, on second thought, I may never use my spare (if my Prius luck holds). So why buy an expensive Prius wheel (unless of course I see one for cheap)? I just have to make sure I get the right bolt pattern for a replacement. And I don't need to buy another General tire for $90... maybe I can find a cheap wheel + tire at junkyard. (I've spent so much this year on the taxes and registration already, lol.)
  19. jerrymildred
    11,517
    14,167
    Tampa, FL
    I got a Corolla donut spare from Ebay for about $100. There is a threaded hole at each of the front corners of the cargo area with threaded plastic plugs in them. I made a d-ring and used the strap that's in one of the little bins under the cargo area to hold it in place. I keep my OEM EVSE and a heavy extension cord coiled inside the spare's rim.
    As for the goop, people say it ruins the tire or the TPMS. I see that claim a lot, but I've never heard that from a repair shop. But they do hate the stuff and I can understand why. Have you ever tried cleaning the inside of a tire??? You don't just pour out the water when you're done. You have to suck it out with a shop vac or something and then blow it dry.
    Besides the spare, I have a tire plug kit in my tool bag in the under deck bin at the back and, like you, I keep a Slime air compressor in the compartment in the back seat.
  20. SeattleBebop1
    163
    105
    Seattle
    I'll have a bit of a harder time finding a wheel/tire combo that's right for me since I'm running bigger tires. Might have to get the wheel and tire separately.
    Nice setup!
    jerrymildred likes this.
