Newpriusbatteries and prolong charger?
Discussion in 'Gen 3 Prius Main Forum' started by Hawaiiprius, Jan 12, 2020.
  1. Hawaiiprius
    Hawaiiprius Junior Member
    Hello. Is anyone using the prolong charger/reconditioner with a battery replacement from newpriusbatteries? I was about to order a new battery set and had the charger already and planned to switch the wiring harness from the oem battery to this new build.
  2. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    I would check with them but I don't think you want to charge newer batteries I have the new battery.... and sold my prolong equipment.
    edthefox5 and Hawaiiprius like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    You can put the harness on, but you won't need to use it for a good bit of time;).
    @2k1Toaster 's kit will last for a good bit of time:).
    But keep the equipment as it never hurts to have it(y).
    Hawaiiprius and Grit like this.
  4. Hawaiiprius
    Thanks Tim Jones and Raytheeagle
    Tim Jones and Raytheeagle like this.
  5. model464
    model464 Junior Member
    27
    23
    Colorado
    2023 Prius Prime
    SE
    I'm assuming the NPB kit uses 8mm nuts like the OEM battery, so you wouldn't need to modify the Prolong harness?
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Why the hell would you do that? I installed a NPB set about 2 months ago its a brand new battery runs perfect. You should not have to prop it up with a charger for years and years. Thats the whole idea its a new battery lol....
    Sell that Prolong Charger big market for that I sold mine for $400 on ebay and it was the first one they made with the light bulb sockets on a board had like 100 views and 40 watchers and 25 bids. It was hot.
    Sold for more than it cost.
    Tim Jones and Grit like this.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Some people do the same with the 12v battery; replaced with a new 12v battery and buy a slow charger to make sure it doesn't fail on them again on their daily driver. Seen those post many times in here.
    Tim Jones likes this.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Entirely different situation.
    The "prolong charger" stresses the battery......outside it's normal operating range.
    A 12 V battery tender keeps it in the "sweet spot" of it's normal operating range.
    If it indeed is a "daily driver", then a battery tender is not necessary but won't do any harm.
    Tim Jones and Aaron Vitolins like this.
