Newsweek Article on Drive by Wire.
Discussion in 'Gen 2 Prius Main Forum' started by prius04, Oct 19, 2004.
  1. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(DaveinOlyWA\";p=\"46149)</div>
    I have heard that the F-16 is the first "Fly-By-Wire" air fighter.
    I believe there was no mechanical connection between the flight control lever and the rudder for backup.
    Correct me if I'm wrong.
    Edit: Found F-16 information...
    "F-16 'Power-by-Wire' Flight Without Back-up A Success"
    http://www.f-16.net/f-16_news_article584.html
    Regards,
    Ken@Japan
  2. bruceha_2000
    bruceha_2000 Senior Member
    3,057
    302
    Northwest VT
    2018 Prius Prime
    <div class='quotetop'>QUOTE(DaveinOlyWA\";p=\"46150)</div>
    GM's hydrogen prototype also has a 'yoke' with an accelerator that can be moved to different front seat positions. I would think the "motorcycle" style twist grip would not be a wonderful thing for all though.
    When I broke my right wrist I could NOT start my Odyssey except by contorting my left hand to the right side of the wheel because I couldn't rotate my right wrist in the cast. Would have LOVED the Prius push button start. If the Odyssey had twist grip, I wouldn't have been able to drive at all. If it is going to be "by wire" perhaps there could be several on the fly user selectable styles.
  3. mmccking
    mmccking Junior Member
    83
    San Jose
    IMO, "by-wire" is if its primary operation is from an electronic connection/interpretation between the user input system, i.e., steering wheel, resulting in a mechanical action or operation, i.e., turning wheel angle, etc.. As for how the action is actually carried out, i.e., computer, hydraulics, gearing, etc.. it doesn't matter.
    Is this the case for the Prius' brakes?
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(mmccking\";p=\"46160)</div>
    Yes...pretty much. Again, there's some redundancy in there and I'm not sure what happens in event of complete power failure...if there is a mechanical backup connection or if there's a back-up electrical system that comes on (there is an electrical capacitor system that actually actuates the brakes) to maintain the by-wire inputs from the driver.
    But, in normal operation it is, indeed, by wire as you described it.
  5. tms13
    tms13 Member
    174
    Lochcarron, UK
    Business Ed. Plus
    As I understand the brakes, the last portion of travel is mechanical (well, hydraulic anyway).
    To demonstrate this, sometime when you are stationary, push the brake pedal down hard. It will come against a stiffer resistance (feels like a pedal stop). Pushing against this is the mechanical brake. In normal operation, you don't get that far of course - only when you're crapping yourself!
  6. rflagg
    rflagg Member
    947
    Springfield, VA
    If your braking is consistent, you can feel when it 'switches' from regen to hydraulic - on my specific car, it's when it goes from 8mph to 7mph, there's a slight forward momentum for a split second. If you're braking hard, or your braking is increasing or decreasing and not constant, you won't notice it.
    -m.
  7. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    rflagg, the 'switch' from regen to hydraulic has no bearing on whether it's 'by wire' or not. In normal cirumstances the hydraulic brakes are actuated by exactly the same electrical signal as the regen.
  8. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ya i need to clarify the controls a bit.
    motion is controlled by moving the controls toward or away from you. experts say that these kinds of controls are more intuitive and reduce reaction times.
    the wheel is not round, it is a type of two handed joystick setup similiar to flight controls.
  9. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(efusco\";p=\"46162)</div>
    So, your definition is semi by-wire with backup.
    My definition is pure by-wire without mechanical(hydraulic) backup.
    Regards,
    Ken@Japan
  10. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    <div class='quotetop'>QUOTE(rflagg\";p=\"46189)</div>
    Idle speed is about 8mph. under 8, your motor starts spinning in the oposite direction to represent idle. this is why you feel your breaks. I wish coastaltech would release the regen/engine on indicator.
  11. scalz
    scalz New Member
    CT
    <div class='quotetop'>QUOTE(prius04\";p=\"46104)</div>
    Just to nit-pick... It was Gilda Radner's Emily Litella that used to say, "Nevermind." -- not Roseanne Rosannadanna.
  12. prius04
    prius04 New Member
    1,161
    NorthEast USA
    Thanks for the info.
    I've been making that Roseanne misattribution for years. I can't wait to use it correctly in the future.
    Now when I use it correctly, some people might be fooled into thinking I'm well informed.
    25 points.
