NexPower Lithium Battery Replacement
Discussion in 'Prius v Accessories and Modifications' started by Andrew Soleman 7022, Oct 13, 2023.
  1. Andrew Soleman 7022
    Andrew Soleman 7022 New Member
    My 2012 Prius V has 141000 miles on it and the hybrid battery doesnt seem to work very well anymore. I am looking to replace it and it was suggested to get the lithium battery upgrade but im not sure if this works for the V model or not. Does anyone have experience with this company or any others to reccomend to solve my issue? Thank you
    V Sport Wagon likes this.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,096
    6,961
    Texas Hill Country
    The v hybrid battery is the same as the hatchback. You will have to diy teardown your battery assembly to the cells and replace them.
  3. Brian1954
    Brian1954 Senior Member
    2,677
    1,071
    South Central PA, USA
    Yes, it works for the Prius v (wagon) model.
    There are many threads in this forum about the lithium battery upgrade and user experience with them. You need to search for them.
    52,847
    'doesn't seem to work well anymore', you may have a different problem which a new battery won't solve
  5. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    I have been running the Nexcell Lithium pack since last Summer (June 2022) version 1 (zero problems). Went from 41-42 mpg on a decent stock battery to this and started immediately seeing 51-53 mpg under the same driving conditions. Recently, upgraded to the Version 2. Not a whole lot more MPG, maybe 1-2 more but much more bottom end torque and temperature management with the new circuit boards and vented case tops. Here's a couple screenshots from 1/2 tank and empty recently (Gen 3 engine in car at the time). You can see this car gets WAY more than your average V. I would take the plunge especially with rising gas prices and invest in your future. (Yes that's 425 miles at half tank and yes, that's also 623.5 miles at the end of the tank).
    Onlooker and Air_Boss like this.
  6. rjparker
    11,096
    6,961
    Texas Hill Country
    Seems your gauge showing over half is slightly off when 8 of the 12 gallons have been used. Regardless, 50 mpg with a heavier v and its higher numerical final drive ratio (3.703 vs 3.268) is impressive, assuming the transaxle was not changed.
    #6 rjparker, Oct 14, 2023
  7. V Sport Wagon
    375
    131
    Southern California
    Transaxle not changed. Also, 1 bar above half is actual half tank btw…
    #7 V Sport Wagon, Oct 14, 2023
  8. rjparker
    11,096
    6,961
    Texas Hill Country
    Missed that part when I read the manual or over my 12 years and 300,000 miles of driving a v. But if you say so I guess my gauge is calibrated wrong.
  9. V Sport Wagon
    375
    131
    Southern California
    I have an ultra gauge plugged into the OBD2 at all times that tells me how much gas is left in the tank. I checked it at this mark and it said 5.95 gallons left both by hand and electronic device.
  10. JMJCATH
    JMJCATH Member
    91
    52
    Here
    I have the NexPower battery in my 2012 Prius v.
  11. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
  12. Ford Galaxie
    Ford Galaxie Member
    63
    30
    16
    Rome, GA
    2014 Prius v wagon
    Yes.
    1. The research and development is done by YOU.
    2. If you consider your wife’s dining room table as your “workbench”, it would be be much better to engage professional assistance and stay the safe road by having “your mechanic” replace it for you using an original one. HOA’s, buying service contracts for everything, landscaping services, etc. Besides you might get something on the driveway and your insignificant other may not approve.
    3. Jack is a great guy. You will find much fanboy fawning over him. However he is just a man. And you should be one, too- and not some owned fanboy b!tch.
    #12 Ford Galaxie, May 21, 2024
  13. AzusaPrius
    AzusaPrius Senior Member
    2,257
    942
    Do not listen to this Ford guy.
    Clearly drinking some hateraid by the gallon.
  14. vvillovv
    vvillovv Senior Member
    4,337
    1,518
    NY
    #14 vvillovv, May 22, 2024
  15. Evan Armstrong
    Evan Armstrong Junior Member
    36
    Corvallis OR
    Hi there, I am having some issues with my NexPower battery installation. It seems to be extremely loose when I torque the pressure bars to spec. They move all over when I rotate the battery to place the sensors back, any suggestions?
  16. vvillovv
    4,337
    1,518
    NY
    Evan Armstrong likes this.
