Nexpower/Project Lithium Battery Issue - Blade #12 Failure?
Discussion in 'Gen 2 Prius Main Forum' started by JasonMRC, Aug 11, 2024.
  1. JasonMRC
    JasonMRC Junior Member
    Washington, GA
    Background:
    • Bought the car in January 2023 with 218k miles. Pretty good condition overall. After testing, the traction battery was on its way out, so I looked into the ProjectLithium batteries. This is my first Prius, but I've learned a fair bit about them over the past two years.
    • I installed a NexPower first batch V2 lithium battery in July of 2023. The car has been driving great since then.
    • Occasionally the dash display fails to light up, but this usually resolves after a day. I believe this is related to the combination meter and unrelated to the present issue.
    • On 8/7/24 I replaced the 12v auxiliary battery because I had deduced it was the cause of a recent no start, and an issue I had in January 2024. That battery was 6 years old.
    The present issue:
    On Friday 8/9, I drove to my work (10 miles, mostly highway 55mph) and it drove fine. When I left in the evening to go home I stopped by a friend's house briefly (about 1 mile from my work) and left the car on with the AC on while I talked with him. The engine never shut off during this 5-10 minute chat which seemed a little odd. I then left and began driving home. As I started accelerating after a stoplight the display beeped and said "Problem" and showed a red symbol, and the HV battery fan in the backseat shot on at high speed. The car drove but seemed to have no acceleration power, so I limped to a nearby gas station. I plugged in the code reader and checked Torque and it showed a 1.2v reading difference between module 12 and the others. The SOC also dropped randomly from 60% to 30%. I turned the car off, waited a minute, and then turned it back on and the issue remained. I switched it into drive and it could still move, but in limp mode. I moved it to the side of the parking lot and then parked it again. The module voltage difference had gone back down to a normal level (0.1-0.2 difference). I thought I would try clearing the code and see if it would let me get home. So I cleared the code and immediately the HV battery fan turned off and the car seemed to be acting normal. I test-drove it around the parking lot a bit and then decided to drive home. I thought it might just be a fluke because I recently replaced the 12v aux battery a few days before (although it had driven fine since I replaced that). I was able to drive all the way home fine (10 miles) and then as I turned onto my street I tested a quick stop and then hard acceleration. After the hard acceleration, the car threw the error, fan on, and lost all acceleration strength. The SOC dropped from about 55% to 30%, then after a moment began rising rapidly 1-1.5% a second until it reached 100%. I parked it and then switched to the Dr. Prius App and received the following reading. Note that Module #12 has double the delta voltage and resistance of the others.
    The codes the system provided both times were: P0A80 and P3024.
    At no point during either issue was the HV battery temperature outside of range.
    Today, Sunday 8/11, after letting the car sit for a day and a half, I went out to run some more tests. When I turned it on it still had a fault code, but this time the code was P3022 and P3000. I cleared that and the car seemed to be idling normally as I watched the stat readouts with the Torque app. I then switched to the Dr. Prius app to see what those readings were.
    Note that module #12 is showing yellow.
    Once the car turned the engine off and stopped charging, #12 was still the highest voltage reading, and the delta voltage on it was also 1.70, compared to the others 0.53-0.59. A few seconds after this picture was taken, the car threw the error again (only P3022). I wanted to try a driving test, so I switched to monitoring it on my tablet for a larger screen. I cleared the codes, got everything connected and loaded up the Dr. Prius app and while I was still idling in park with the engine off, it threw the code again (only P3022) - turning the fan and engine on. The following picture from my tablet is directly after this.
    All of the Sunday tests were taken while idling in my driveway. I never actually drove it anywhere. I haven't driven it anywhere since I got home Friday night.
    I have contacted Jack at NexPower and now come here for suggestions and solutions. Are there any other tests I should try? Are these all symptoms of a bad #12 blade, or something else?
    All help is greatly appreciated. Thank you in advance!
  2. ChapmanF
    19,027
    it definitely looks like that module has seen better days. The pack is around 12 or 13 months old? How long do you have coverage from NexPower?
  3. AzusaPrius
    AzusaPrius Senior Member
    2,257
    945
    I have notified Jack of your issue, he should get back to you shortly.
    JasonMRC and PriusCamper like this.
  4. jacktheripper
    jacktheripper Senior Member
    284
    558
    Hi @JasonMRC ,
    Thanks for the screenshots, it looks like the M8 nuts at blade #12 is loosed causing the double IR. I would recommend to open up the metal case and make sure all M8 nuts got secured to 3 ft-lbs. of torque.
    Also, if you have the V2.0, we will upgrade you to the new V3 sodium-ion battery, feel free to send pictures to [email protected] and we will help you get back on the road.
    Best Regards,
    Jack
    JasonMRC and ericbecky like this.
  5. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    That's pretty good check that out and see if that's the case seems perfectly reasonable but not good but reasonable assumption.
  6. Brian1954
    Brian1954 Senior Member
    2,688
    1,074
    South Central PA, USA
    @JasonMRC , Please give an update if you found any loose nuts on the blade terminals?
  7. JasonMRC
    Washington, GA
    Thanks for the responses, everyone!
    Today I took it apart and checked all the nuts. They were all tight and there was no corrosion anywhere except for a very minor amount on the main negative terminal wire, but not the contact portion. I inspected all of the blades and they all looked good - no signs of bulging, burning, corrosion, wear, etc. Unfortunately, I did not have my meter to check the voltage of the blades, so I'll do that another day.
    Shoutout to @jacktheripper for superb customer service! He had a new Sodium V3 shipped out to me on Monday and I received it Friday - just 7 days after the blade 12 failure. I installed the pack and did a basic test drive and all systems seem to be working properly. I will do a more thorough test tomorrow.
    pollypocket53132 and Brian1954 like this.
  8. Brian1954
    2,688
    1,074
    So Jack sent you a v3 battery on Monday 8/12 even before you checked for loose nuts today, Saturday, 8/17. Jack knew it was not a loose nut and that it was a bad blade. Hopefully, the v3 sodium-ion battery will work better than the v2 LiFePo battery. I assume the v3 that you received is a prototype battery and not the production v3.
    #8 Brian1954, Aug 17, 2024
  9. ChapmanF
    19,027
    I don't know if it's certain Jack knew that, or just wanted to get a replacement en route so the OP could get back on the road promptly in any case. Could be read either way.
  10. Brian1954
    2,688
    1,074
    Yes, I agree with you. I applaud Jack for being very proactive in sending the v3 battery so quickly. I am guessing that Jack has seen this problem many times with the v2 battery, and he wanted to take care of this customer. From what I have read in this forum, Jack is very good when dealing with warranty issues for his batteries.
  11. JasonMRC
    Washington, GA
    I can't speak to whether he "knew" or not. I was pretty confident that everything was going to be tight because I know I secured them well when I installed it. I do live on a bumpy driveway though, so anything is possible.
    Either way, I appreciate his swift service.
    I don't think it's a prototype version, as it doesn't look like the pictures of prototypes that I've seen.
    So far it seems like the v3 isn't giving quite as much "oomph" as the v2 lithium did, but I've only driven about 70 miles so far. Hopefully the computer will learn the new battery and use it more soon.
    Brian1954 likes this.
  12. Rinaun
    Rinaun Junior Member
    Hey All,
    I'm having almost the exact same issue. I'll grab some photos in a bit, but it looks like I have a single bad blade in my battery. Really bummed about this as I paid a ton for the battery and hardly used it (put less than 15-20k miles on it in 2-3 years). Hoping it's just a quick fix by replacing a bad blade, but I'm kinda scared these V2's (and V1s) were not as high quality as I had hoped.
    Any advice on moving forward Jack? I'll be shooting an email regardless soon to figure out what I can do to salvage the battery/get it working again.
  13. bisco
    52,862
  14. Rinaun
    Already posted in that thread, but half my messages sit as "waiting for moderator". Either way I've spoken to the owner and he's just trying to upsell me a new battery for almost a grand. With how long this battery lasted, I have no idea why anyone would spend more money with the company in hopes they can "fix it this time". The first battery was a whopping 2400, which is just insane for how long it lasted.
    I genuinely want to know from him/his team how a battery in a climate-controlled evnironment after 15k miles and under 2 years has failing packs.
    I also feel that there might be some people hostile to Nexpower staff/team, but at the same time, I think there's a bit of a cover-up with how big of a risk/liability these V2/V2.5's are. If I was a business owner and saw how serious the issues were with V2 and 2.5s, I would have been more adamant with recalling them or warrantying them.
    I hope to god there isn't some news article about someone's house burning down (or worse).
  15. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    The problem is they used lithium cells without a lithium battery management system (bms). The beginning of the end was at least one fire reported here with pics. They had warnings from an engineer they elected not to hire but that guy was shut down by our moderator and lawsuit threats from the company.
    It will likely happen and the company will hide behind their LLC.
    MAX2 likes this.
  16. Rinaun
    I have no problem bringing this up to relevant agencies in California. He can duck all he wants behind an LLC but at the end of the day I have no issue making sure people know his products are inherently unsafe and are huge fire hazards. I'm having a paid electrical engineer look at the battery as we speak (it's headed onto our personal lift at our automotive shop in an hour or so).
    I've had him in Emails telling me multiple times to just pay out and have him repair the battery/replace it. I'm going to take the battery out today, document everything, and file all information to relevant agencies. I have also no problem cold-calling their potential customers/vendors/distributors and explaining the situation to them. It's just not worth the risk for most companies.
    Fun Fact: once I report this, there's a good chance people who have this modification won't be allowed to park their cars in certain places (obviously if it's known this modification was done). No way in hell is a reputable company going to allow someone to park a lithium bomb on their property/garage/enclosure. I actually parked the car in the field after finding out how dangerous it is.
    #16 Rinaun, May 3, 2025
  17. Rinaun
    On a side note, Is there any way to MAKE a correct BMS system to make this even work? I'm betting a lot of this cannot be avoided without high-voltage power regulation or some sort of high charge/discharge offload bank (IE a power source just to mediate spikes and direct that impact off from the lipos). I'm a curious soul so if anyone wants to jump on a discord call and explain to me a solution, I'm all ears. We have 5+ gen 1-2 priuses here, and a LOT of these vehicles are essentially flashlights (once the batteries die, it's useless for even pet projects). Having an ACTUAL working DIY BMS system to convert stuff might be clunky/large/take up the trunk, but it would be a good step in making sure less stuff ends up in a landfill. I'd love some BMS/battery setup that's made with just a bunch of RC-style or even solar-battery-sized packs (so you can fix/swap bad packs and stuff). An example of practical usages/purposes for a customizable BMS would be the G1/G2 Priuses powering houses/acting as generators for UPSes, as I see people create on here/other sites.
    I'm not a PCB/electrical engineer, but I just got done sending a 4 layer PCB to oshpark, so making a custom circuit (or having it laid out and printed from someone else's schematics) wouldn't be too crazy. I messaged the other gentleman who posts on the issue commonly on Reddit and asked him a similar question.
    On another note, the amount of people slandering that dude is insane. I'm very passionate about a lot of stuff, and can get hotheaded when people are stubborn with stuff I'm really skilled in, and I feel that's probably what happened in that situation. That being said, safety (especially with lipos) is a huge huge deal to me and any concerns over these batteries (and the fact NO RECALL WAS DONE FOR A HUGE INSURANCE LIABILITY OR NOTICE TO CUSTOMERS) is like................such a huge deal I'm amazed people were trying to project him as some crazy guy trying to ruin Nexpower's reputation. Nearly every single one of his facts is correct, especially about V2 and 2.5. I see the circuit for 2.5, it's just....................yeah that's some hack shit. Sorry.
    I'm very confused and concerned why some people on this site are defending this when it's clear all these packs are ticking timebombs. It's not a matter of IF, it's WHEN the next pack will explode/catch the car on fire.
  18. rjparker
    11,116
    6,974
    Texas Hill Country
    The strange thing was you could buy brand new Toyota nimh for the same price and easily get ten to fifteen troublefree years, just like the original cells. The sales pitch for aftermarket lithium was extended ev range (maybe 2.5 miles) and more power (also questionable but taking advantage of the factory bms thinking the nimh cells were overcharged). The early advocates received "beta" lithium and discount codes to hand out for commissions.
    Many of us with background knowledge were asking how a factory nimh bms was interfaced to an appropriate lithium bms. Trade secret until failures occurred and it was determined voltage feedback was modified to avoid codes.
    Toyota offered lithium and the appropriate bms in gen3 Prius v's sold in other countries. The packs were installed under the middle console leaving room for a third row in those v's. That gen3 was sold through 2022 using the same 1.8L gen3 engine config with updated pistons, rings, head gasket, egr valve, intake and software.
    MAX2 likes this.
  19. Rinaun
    Oh, absolutely. I wasn't into BMS/Battery tech 2-3 years ago, but now I'm decently hip on how the basics work and knew coming back to this pack after it threw an error was going to be a shit-show. I was really hoping it was just going to be at most pulling the battery and having Nexpower service/replace the battery (since it's obvious it's a huge liability/a dud) with maybe me paying for shipping, but I cannot fathom spending more money with his company.
    Not only that, but he wants the old battery back AND 1300 dollars. I feel that EITHER/OR is acceptable, but me sending it back just makes no sense at all. I can easily get my old core refurbished and the car sold off, which is what will most likely happen. I'll take the old battery, tear it apart, document how badly it performed/of a condition the cells are in after FIFTEEN THOUSAND MILES and also include Jack's "please I'm going bankrupt give me 1300$ or you're screwed" emails with the documentation.
  20. rjparker
    11,116
    6,974
    Texas Hill Country
    . $1300?
    I thought these prices were high.
