NEXT GEN VOLT
Discussion in 'Chevrolet Volt' started by dbcassidy, Jun 6, 2012.
  1. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Looking to the future, what would you like to see in the next gen Volt?
    - Extended battery range?
    - Lower overall cost of vehicle?
    - More interior room?
    DBCassidy
  2. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I think 2 of the 3 you list are a must to gain wider acceptance - interior room at least needs to be better packaged and the price needs to be more competitive.
  3. gwmort
    gwmort Active Member
    985
    211
    Delaware
    I'd most like for future battery improvements to be compatible with the cars already on the road. I am envisioning a pack of the same size, but more capacity and perhaps less weight that can be used in the next gen volts but also swapped out for the old packs in the first gen volts.
  4. Zythryn
    Zythryn Senior Member
    6,411
    4,411
    Better batteries/EV range would be one. Although don't need much, say another 10 miles.
    Have no need for more interior space although it wouldn't be a detriment if it had a little more back seat legroom.
    Lower cost is always nice for any vehicle as long as it isn't to the detriment of other features.
  5. scottf200
    scottf200 Member
    220
    61
    Chicagoland
    <delete> after seeing it is DBs thread.
  6. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    lower price, better efficiency (both electricity and gasoline). why guzzle both?
    usbseawolf2000 likes this.
  7. Flying White Dutchman
    4,376
    313
    No ice
    -Htc Tapatalk
  8. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Seating for five
    Engine that runs on 87 octane. Maybe trade performance for better economy
    Longer EV range (of course)
    Reliability, reliability, reliability
  9. dbcassidy
    1,581
    290
    Too bad for you. This thread is looking for inputs on product improvements. People like to see the product evolve and move forward.
    Peace,
    DBCassidy
  10. Zythryn
    6,411
    4,411
    Wow, they just released some info on the 2013 Volt.
    EPA EV range increased from 35 to 38. Excellent news although I would still like to see another 7 to 12 miles on the range.
  11. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Lower price, even if that means lower range. More efficient gas engine will negate/relief that. That should also enable the 5th seat with smaller battery.
    The bottom line, put the existing components to more use. Get rid of the EV purity notion and promote the teamwork of the hybrid powertrain. The Hold button for the 2013 Volt is a good start.
    john1701a likes this.
  12. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    That's exactly what was meant by "too little, too slowly".
    We all knew the needed components were present, but the chosen configuration didn't match what mainstream consumers required.
    Purity is a low priority for middle-market. They will benefit greatly from a significant reduction, which is what the hybrid system could deliver.
  13. brad_rules_man
    brad_rules_man Hybrid electric revolutionizer
    716
    76
    Effingham
    I would like to see a blended mode that more uses the gas engine when I know I am going to travel long distances. Perhaps then it could do a bit better on the overall mpg? Perhaps the gas engine is more efficient to be used? Oddly though they claim that it needs to be over 70mph for it to be more efficient. Basically I would like to see some performance curves of the different theoretical operating situations. I believe the higher octane has several advantages. It keeps better and many Volt owners I know usually see the engine maintenance mode so they need that. More battery capacity would be awesome! I want a backup though, because I can't have 2 cars but I want to drive EV here and have the ability to drive cross country. I feel though that even having a really small engine like 50hp at the most, even smaller possibly could be utilized. You would have to let your car know you were going to be traveling great distances though, because even with a fully charged battery, with that limited generation you would have to immediately start charging. Perhaps the computer could tell you how far you could drive at various speeds the same way it calculates it's range. That would be neat to see!
  14. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Not sure where you got the 70mph is better.. When the volt is is mode 3 (ICE+EV in parallel-hybrid mode) is the most efficient mode for the ICE, which can occur anytime from 35-??mph (the upper end depends on road load and wind.. more than just speed). The car has to decide its not accelerating, or it waits to change to two-motor ER (mode 3). Because the areo-drag increases quadratically with speed, its most efficient as on gas as long as you can keep it in two-motor ER mode. (Well 2-motor EV might be more efficient, but its only avaible at very high-speed and low-load, like downhill at 75mph).
    Here are some chart's showing the various modes for speedsvs tourque.
    Here is a related plot.. the KWH/mile consumed for the Volt at various speeds (measured by user)
    http://gm-volt.com/forum/attachment.php?attachmentid=2242&d=1309465048[​IMG]
  15. brad_rules_man
    716
    76
    Effingham
    Thank you! I had heard from almost every source possible that Volt engine came on only as a "generator" to extend the range. The gasoline engine is only supposedly coupled onto the drivetrain at speeds of 70mph+ because the engineers said that it was more efficient at that point. A lot of people complained as the drivetrain was supposed to be 100% EV and the engine was only for generating electricity. There is supposedly a "3rd clutch" or whatever to keep it disconnected from providing torque to the drivetrain until those conditions are met. Have I heard wrong?
  16. drinnovation
    2,027
    586
    65
    CO
    yup what you heard is wrong. It can be a serial hybrid (i.e. using engine for generator) but as you can see from the above chart (figue 18 from a GM paper), two-motor ER driving can occur from about 60 kph (about 35mph) anywhere up to 100mph. the two-motor ER (i.e. parallel-hybrid) mode is 10-15% more efficient than serial hybrid in the range were it is used.
    There is nice video on youtube about it.
    In that video around 33:40-34:30 they show extened range driving and shifting from 1 motor serial hybrid mode, accelerating to 70, then settling at 70, the clutches changing and the car switches to two-motor ER mode. I think that is where the magic 70 came from, but its was just an example speed.
    If you want to understand how the volt really works, I recommend the whole 40m video.
  17. brad_rules_man
    716
    76
    Effingham
    I'm going to double check. Because I was hearing this 70mph number directly from posts by Volt engineers. This video seems to date back before the actual production model hit the market. However, it is after their first release that it wouldn't always be a "true serial hybrid." Never fear, I'm not upset or offended. Efficient is ALWAYS better! I appreciate the video, I always wanted to visualize how the Volt's drivetrain functioned and never did come across this video. Much like this link for the Prius: Toyota Prius - Power Split Device
  18. drinnovation
    2,027
    586
    65
    CO
    Well if you can point to the article's I'll examine it. There are articles like this one from motortrend
    Unbolting the Chevy Volt to See How it Ticks - Motor Trend
    That also get the 70mph wrong.. (but I think they got it from the example in the video, as the figures look just like segments of the video.
    It is also possible its from a map such as these
    which show composite engine efficiency as a function of torque and speed. But the torque there is dyno-torque so its ignoring wind resistance, which grows quadratically with speed. So while there is a region of 87 at around 70mph, its only going to achieve that if you are only using 300nm, which at 70mph means you are going downhill or have a stiff tail-wind. Comparing with figure 18 above you'll see its also about where 2-EV serial mode can happen (which is why i made that comment before.. i presumed that was in the 2EV mode.. but maybe its still 2-motor ER).
  19. austingreen
    austingreen Senior Member
    13,713
    4,231
    Austin, TX, USA
    Motor Trend did indeed publish 70mph from there testing. At that point gm was mum, but later clarified that it can happen at lower speeds. I don't think they ever gave a full statement on what torque/speed transition will occur.
  20. brad_rules_man
    716
    76
    Effingham
    Well I shall continue to look into it and get back to you. I know I saw speeds of over 69 or 70mph somewhere. And in this video they answer questions on the presentation. They said there was no "direct" mechanical linkage. Knowing what I know about the Prius, that's sort of a funny way to put it because really there is... but I think it happens more as a passive leaching of the power since it's already producing anyway. She did say it had to be "high speed situations" but then again that's not definitive. It's kind of open ended. I will check back later on when I can do some research!
