Next generation Prolong Battery Charger photos
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jeff652, Mar 23, 2016.
  1. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    Hi Guys. The PiP is Lithium. Our products are only for NiMh batteries. Once we finish the next generation Pro Reconditioning system and After cooler, I plan to start investigating Lithium to see if their is anything that can be done. But as of now our products in general should not be used on Lithium batteries.
    jerrymildred, Prodigyplace and SFO like this.
  2. jeff652
    607
    624
    Idaho
    Yeah agreed it is not a consumer product. And it has been an all consuming undertaking to get it done, stable, and 'finished' from an engineering/R&D/QA perspective. This is why I have been MIA around here.
    Soon we should be done. Then focus will shift to merging them into a single box. (Yay more work!)
  3. Prodigyplace
    12,525
    11,745
    Central Virginia
    @Raytheeagle @jerrymildred and I have still been trying to promote your products where appropriate.
    Thank you for the update. I think some people wondered why you were MIA.
    Raytheeagle and jerrymildred like this.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,420
    3,294
    Madison, Wisconsin
    You guys would not believe how hard working Jeff is!
    Between creating, testing and producing the product, plus going around the country to trade shows to promote the product I'm surprised he has time for anything else.
  5. Prodigyplace
    12,525
    11,745
    Central Virginia
    From a satisfied customer, I hope?
    Or no time to test? :D
  6. ericbecky
    4,420
    3,294
    Madison, Wisconsin
    I'm talking about his dedication to the business in general.
    I've been working on hybrids since 2003 and have had my own charging/discharging equipment since long before Jeff ever came on the scene.
    Back then we had to homebrew our own or look to a tinkerers to toss together the equipment we need.
    #26 ericbecky, Jan 16, 2018
    Raytheeagle and Prodigyplace like this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I’ve been to his shop and he helped me out:).
    The least I can do is share my experience and help others see the value;).
    An all in one box would be a fantastic option(y).
    edthefox5, Prodigyplace and SFO like this.
  8. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Especially if it has enough 'fuzzy logic' to do the job right the first time.
  9. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    Lithium is a totally different chemistry than NiMH and because of that NiMH benefits from "exercise" while lithium deterioration depends entirely on cycles. There's also a big difference in the quality of cells from Japan (ex Panasonic) vs cheaper chinese cells. Lithium also doesn't like deep discharges so I imagine that Toyota has looked at this very carefully and adjusted their hybrid management software accordingly.
    You can see how cycles go up non-linearly with the depth of discharge.
  10. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Pretty sexy curve on that Winston, where would one obtain an affordable 12v version of such?
    And could it replace the conventional AGM in a prius?
  11. gamma742
    gamma742 Member
    178
    73
    Luxury
    @jeff652 Is there any consideration of adding pigtail to trickle charge the 12v?
    I have heard some recommend that the 12v should be placed on a battery tender of some sort during the charger/discharger process.
  12. Prodigyplace
    12,525
    11,745
    Central Virginia
    The 12v is lead-acid AGM, a different battery chemistry.
  13. gamma742
    gamma742 Member
    178
    73
    Luxury
    Does the HA Charger/Discharger power the HV Cooling Fan?
    SFO likes this.
  14. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Yes, both do I believe.
    Prodigyplace and gamma742 like this.
  15. Prodigyplace
    12,525
    11,745
    Central Virginia
    @Raytheeagle can you answer definitively?
    Raytheeagle likes this.
  16. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Integrated into the wiring harness and runs at full blast all the time during charging and discharging operation with the Hybrid Automotive equipment (y).
    #36 Raytheeagle, Jan 17, 2018
    srellim234 and Prodigyplace like this.
  17. Prodigyplace
    12,525
    11,745
    Central Virginia
    Thanks.
    I always hate it when somebody starts their answer "I think...". :eek:
  18. gamma742
    gamma742 Member
    178
    73
    Luxury
    Thanks guys, my concern was that the cooling fan might run down the 12v during the process.
    Prodigyplace likes this.
  19. MTL_hihy
    536
    261
    Maritimes, Canada
    No need for that, just get yourself a CTEK 3300 12V smart charger and hook it up for 24 hours twice a year when you do the traction battery, works great.
