NHW20 Front Hub Flange Thread
Discussion in 'Gen 2 Prius Main Forum' started by mxxxo, Jan 19, 2021.
Tags:
  1. mxxxo
    mxxxo New Member
    Bulgaria
    Hello all,
    First post, I hope I`m not violating any rules here.
    Does someone have information, what the h*ll is the wheel bearing flange thread size of NHW20 front axle.
    To sound less foolish, I`m using the bearing assembly for a project due to its suitable mechanical properties, no cars would be harmed !
    I`ve found the bolt part number 90105-10469 , but no info about it whatsoever.
    Tried Metric M10x1.5, Imperial 3/8-16 (UNC), Imperial 3/8-24 (UNF) to no avail !
    Thanks for your time in advance & sorry for the lousy English.
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    Your English works fine here. FYI, you're moderated for five (5) posts, which can cause delays in posting and replying.
    Try one with a 1.25mm pitch, and you may want a 'hardened' flange bolt for this application.
    Of course we're curious what the "project" is?
    mxxxo, Raytheeagle and PriusCamper like this.
  3. mxxxo
    mxxxo New Member
    Bulgaria
    Thank you SFO, M10x1.25 it is !
    I want to use the bearing to support the center of a large abstract painting, in order to be able to rotate it and get "another" abstract painting.
    Got it from a scrap yard (the hub, not the painting :) ), and found it was Prius by the product number.
    Thanks again !
    SFO likes this.
  4. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    If the artist allows, it would be great if you could post images of the painting in the various abstracted forms.
    Just copy and paste the image(s) into the reply field (like you would with text), don't worry about image hosting and other websites.
