NiMH Hybrid Battery Modules
Discussion in 'Gen 3 Prius Technical Discussion' started by indel, Jan 16, 2026.
  1. indel
    indel Member
    283
    89
    Northwest Indiana
    There are quite a few videos available now on hybrid battery reconditioning. Often times, people are forced to replace a few or more modules, which begs the question(s):
    1. Are we entirely dependent upon the pool of modules from totaled vehicles or retired batteries from vehicles that went the K or Li route?
    2. If so, why hasn't anyone tried to manufacture these modules from scratch? How hard can it be to make NiMH cells?
    3. What is Toyota doing with the core returns on their battery packs? Conventional wisdom and some commentary on forums I have read suggests that they are ensuring recycling of hazardous materials. What is the likelihood that their new packs are simply recycled/refurbished core returns? And perhaps only the new vehicles are getting batteries with completely new modules? In other words, are you getting your money's worth when spending at least $2500 in parts and anywhere from $500-1500 in labor, especially since the warranty on even dealer installed packs maxes out at 3 years.
  2. ASRDogman
    ASRDogman Senior Member
    8,053
    4,083
    why don't YOU make them. It's easy....
  3. indel
    indel Member
    283
    89
    Northwest Indiana
    Not being helpful. The intent of my post is not snark, but genuine curiosity. May be you can share some of your wisdom answering the questions I posed instead of snarking.
  4. ASRDogman
    8,053
    4,083
    Yes I am being helpful. You want someone else to do it. It was your idea, then YOU should do it.
    It was not "snarky", it was a genuine response. I shared my wisdom. You just didn't like the answer.
    You only want answers that please you, when they make you work, you can't handle it.
    Man up and except both sides of an answer to your question.
    Why don't you research yourself and see what is involved in starting from scratch and building a battery.
    Use your money and time, don't expect anyone else to do it if you are not willing to put forth the work yourself.
    If you can't handle any answer you don't like, don't ask the question.
  5. ChapmanF
    18,988
    I would read "how hard can it be to make NiMH cells?" as something sort of like "how hard for a business with appropriate metallurgical and plastic-molding and manufacturing tooling?" and not as, say, "could I make them in my garage?"....
  6. indel
    indel Member
    283
    89
    Northwest Indiana
    That's exactly what I was aiming for. I mean look at the range of aftermarket parts we have available for any vehicle for any year that are "exact" replicas of the OEM. So why not battery modules?
    I understand this is the internet and everyone is entitled to their opinion, but there is absolutely no need for toxicity on this forum. I have put him on "ignore" so hopefully I don't have to deal with him again. I am here for one reason and one reason only. To learn and to share.
    mjoo likes this.
  7. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    I think it's more to do with ownership. No one is going to manufacture the Toyota modules due to fear of getting sued. Maybe shops in China don't care, who knows.
    But there are new designs you can buy that are the same chemistry, just look at the cylindrical packs as an example.
  8. ASRDogman
    8,053
    4,083
    There are copy right laws. But there are different manufacturers you can seek out.
    But new tech's are going to the sodium-ion battery technology.
    It costs less to produce, it's less dangerous, you don't expose children to the dangers of mining lithium,
    it's doesn't shut down when it gets below freezing, and can be charged in cold weather, and doesn't
    explode when exposed to water, it's lighter too.
    Manufacturers are starting to move toward Sodium-ion technology.
  9. BiomedO1
    BiomedO1 Senior Member
    4,550
    2,393
    Left Coast
    You can buy brand new individual modules, but mixing new batteries with 15+ year old ones isn't ideal. Neither is putting in an old battery that's less worn out than the rest; but people do that and can't figure out why the traction pack keeps failing. It's pretty obvious to me. You can lead a horse to water - but you just can't make them drink if they refuse to......
    IMHO: That's a common sense, critical thinking issue....
    xw20_driver likes this.
  10. indel
    indel Member
    283
    89
    Northwest Indiana
    Are those the same ones that chrisfix shows in his video on battery replacement?
  11. indel
    indel Member
    283
    89
    Northwest Indiana
    Good point. How does one tell if a module purchased from ebay is too old to be put into a pack that's being reconditioned?
  12. BiomedO1
    4,550
    2,393
    Left Coast
    Expensive battery test and exercise equipment.
    There's a date/manufacturing code stamped into the battery plastic. Usually month and year produced and run code - for QC and recall purposes.
    indel likes this.
  13. BiomedO1
    4,550
    2,393
    Left Coast
    Yea; while Chrisfix videos earn him money - those packs don't last like the OEM ones. I've heard some failing in as short as two years. While initial mpg improve when installed; they drop back off in about 6 months - but they don't throw a battery code, so NO warranty.
    #13 BiomedO1, Jan 22, 2026
  14. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    Well - keep in mind there are several varieties of those cylindrical cells floating around. The cheap ones definitely don't last as long, I don't know what the quality is of the pack that chrisfix used. In a couple of the reviews I saw of these they were not the same pack as that one (or for the 3rd gen Prius for that matter).
  15. BiomedO1
    4,550
    2,393
    Left Coast
    He more than likely got it for a steep discount or free for placing it on his channel. That's how marketing and advertising works. That's the same reason retired ball players and actors end up selling stuff on commercials.
    YMMV
  16. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    Oh I'm sure he got it for free. He even said he paid some absurd low price for the Prius itself which looks pristine. Even with a dead traction battery car would be worth far more so I didn't buy that at all. Anyway, going off the topic there...
    BiomedO1 likes this.
  17. ASRDogman
    8,053
    4,083
    You can lead a horse to water AND make it drink. Ask any horse person, they will tell you to put
    salt in their oats....
    It's is never good to use used batteries with new batteries. No matter what type or size of the batteries.
    New is always BEST, but the wallet determines what a person can get.
  18. BiomedO1
    4,550
    2,393
    Left Coast
    Soft drink manufacturers do that to their sodas - The sugar and caffeine sucks you in; the salt keeps you drinking.o_O:rolleyes::love:
    A mind is a terrible thing to waste.......
    #18 BiomedO1, Jan 23, 2026
  19. indel
    indel Member
    283
    89
    Northwest Indiana
    What years should one target when buying the modules? I feel like that will further reduce the suitable inventory on ebay. I found some modules made in 2009. That's three years before my model year.
  20. BiomedO1
    4,550
    2,393
    Left Coast
    IMHO; it really doesn't matter - the newer cluster of stronger modules will simply place more stain on the old cluster of modules. The newer cluster will charge and output faster and longer than the older cluster of modules - causing them to fail. I call it the wack-a-mole effect, because the next traction pack error code will simply point to another cluster of modules that died because they couldn't keep up with the newer cluster. Some people has been lucky and has gotten several years more out of their traction packs. Those are the customers that rebuilders use as references, but there's probably 3-4 others that would disagree with that.
    If your going to rebuild your pack, just expect it to last you a few years at best. It certainly isn't going to last another 10-15 years.
