NiMH Modules (RAV4 18+)
Discussion in 'Toyota Hybrids and EVs' started by Hybrid479, Sep 4, 2025.
  1. Hybrid479
    Hybrid479 New Member
    Fayetteville AR
    Hello! I’m hoping someone can help me determine something.
    all I need is someone to hopefully have a photo or 2 of the inside of a 18+ rav4 NiMH battery. The service manual has a good bit of detail in their drawing but I do not work at a dealer and these cars would only be having warranty claims. By the book it shows the case is opened during R&R.
    I have searched high and low and cannot find any photos and I cannot find any cores to be able to dissect.
  2. Prodigyplace
    12,696
    11,840
    Central Virginia
    What year are you looking for? The design changed between 2018 & 2019 model years,
    If it is the same as the Prius Prime, this video may help.
  3. Hybrid479
    Fayetteville AR
    A 2018-2023 NiMH only. The main change to my understanding is that some started coming with lithium as well. However this is the answer I’m after did the *NiMH* cells have a form factor change in that transition as well.
    a prime battery would be lithium so it’s no applicable here. Thank you though.
    Prodigyplace likes this.
  4. Prodigyplace
    12,696
    11,840
    Central Virginia
    Toyota TIS may have some information on that.
  5. Hybrid479
    Fayetteville AR
    I have TIS it does not. It has some basic diagrams that make it look very very similar but I want to be certain before spending $1000 to harvest some nearly new modules.
    TIS just says 34 7.2v modules nothing specific to their form factor. I assume they are the same but assuming gets you into a bad place.
  6. Prodigyplace
    12,696
    11,840
    Central Virginia
    Compare part numbers? If they are the same, no assuming involved.
  7. Hybrid479
    Fayetteville AR
    Sadly there isn’t a part number for the modules themselves. The battery p/n will only confirm if NiMH or lithium. :(
    I’m gonna have to be the test experiment I think unless someone chimes in from a dealer who’s had to swap one under warranty.
    TIS shows opening the case when swapping a failed battery.
