Featured Nissan motor analysis Munro
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Aug 1, 2025.
  1. bwilson4web
    16,552
    It is much easier with the improved, service menu. For example, monitoring the battery temperature management when charging:
    This is the battery cooling before I plugged in to charge. I have a full movie showing what happens if you don't 'precondition' the battery.
    My Model 3 has an energy report that shows a significant effect on the battery if you precondition before plugging in to "save charging time." But I reason that the battery is already at the 'steady state' temperature from driving and I'm too cheap to save a few seconds.
    Sure enough, the full movie recording shows an initial chilling occurring when charging starts but soon as the charging curve significantly slows down, so too the chilling of the inverter, motor or battery. I can actually watch the coolant flow valving in the 5-way coolant bottle.
    Isaac Zachary likes this.
  2. bwilson4web
    16,552
    I appreciate what he teaches but the enhanced service menu lets the owner/operator see what is going on at a system level. The diagnostic package has its place for the next level of repair and maintenance.
    I have speculated that adding a BMW i3 Range Extender on a bumper platform could make my Model 3 into a super "range extender." But I have a few years to investigate and work on a design to develop and test. Of course, mine will be the range extender engine powered by dried grass clippings, pine needles, dried leaves, and other yard clippings. <GRINS>
    The BMW range extender generator has the the same nominal output voltage as my Tesla pack. The battery terminals are under the "top hat." The rest is just an undergraduate engineering exercise.
  3. mikefocke
    4,083
    1,865
    Sanford, NC
    Might want to edit as there are 3 explanations for ~80 MPH and I think those should vary.
  4. bwilson4web
    16,552
    There are three because:
    1. 10 minute charge session
      • Provides enough charge for 75 minutes at 80 mph
    2. 20 minute charge session
      • Provides enough charge for 110 minutes at 80 mph
    3. 30 minute charge session
      • Provides enough charge for 130 minutes at 80 mph
    The shortest charge session, 10 minutes, is at the fastest charge rate but limits how long, 75 minutes, we can drive at 80 mph. The total drive and charge time is the sum, 10+75 minutes. However, the drive distance is 80 * (75/60) = 100 miles.
    The longest charge session, 30 minutes, goes further but only for 130 minutes. So the rule of thumb is:
    • Short duration fastest charge rate but shortest drive duration
    • Long duration slowest charge rate but slightly longer drive duration
    It is how EVs like my Model 3 work.
