nitrogen tires
Discussion in 'Prime Main Forum (2017-2022)' started by martydallas, May 6, 2017.
  1. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    Hydrogen goes BOOM is true but its lighter than air so theres less tire drag giving the car an extra 5 mpg..its worth the risk
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    I want to congratulate you guys for turning a thread with a simple question into "nerds on parade". I believe we've found the next group of cast members for Big Bang Theory. (love that show)
    o_O
    wjtracy and Prius from Dad like this.
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Nitrogen in tires is one of several "hot button" topics, in this case conflated with H2 politics ..wild ride indeed!
  4. Pdog808
    Pdog808 Active Member
    434
    290
    Los Angeles
    2018 Prius Prime
    Not sure if anyone mentioned it but Costco members can fill with nitrogen for free. You just need to pull up in front of their mechanic bays. There is usually a nitrogen hose that is meant for members to top off their tires.
    From my observations, nitrogen leaks a lot slower than regular air in normal tire operation. Maybe 2x or more slower leakage.
    wjtracy likes this.
  5. martydallas
    martydallas Member
    106
    84
    Dallas, tx
    Thank you, someone had mentioned Cosco filled tires up for those buying tires but did not indicate that you could just self-service, very good to know I will check it out later tonight for I’m going to buy food for a pool party this weekend expecting 70+ at my house yes crazy, but should be fun :)
    Pdog808 likes this.
  6. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Deleted
  7. Pdog808
    434
    290
    Los Angeles
    2018 Prius Prime
    @martydallas - I can't guarantee every Costco will let you do that but the ones here in Southern Cal are OK with it.
    If you can fit all the food for 70+ people into one trip on the Prime I think everyone will be impressed.
  8. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    The conclusion you have reached is flawed; not supported by a wide range of facts.
  9. Pdog808
    434
    290
    Los Angeles
    2018 Prius Prime
    Sure maybe 2x is stretching it but I do go long periods of time before I top off the tires (yes, I know that's not great but it is what it is). Ever since I started using nitrogen, there has been a noticeable difference in tire pressure loss. I'm saying something like going from 44 PSI (max tire pressure) down to 36 PSI over 3 months. Driving about 1K miles per month.I used to see pressure losses to below 30 with regular air in some extreme cases over approximately same period. This was all before Costco went to nitrogen by the way.
    Remember, the tests quoted by Consumer Reports are for tires left sitting stationary outside for a year. I am only going by what I see in real world usage which seems to indicate to me that pressure loss is reduced quite a bit from normal air.
    Bottom line is that since I can get nitrogen fill ups for free at Costco, I always try to take advantage of it. Their membership fees force me to try to take advantage of everything I can !! :)
  10. Lee Jay
    5,850
    4,036
    Those tires stink.
    With regular air I usually lose about 0.25psi per month.
  11. Pdog808
    434
    290
    Los Angeles
    2018 Prius Prime
    Bridgestones. Yeah I know I should have gotten Michelins but the price delta was pretty large - at least the ones quoted by Costco.
  12. Mendel Leisk
    42,246
    Price difference ?? (n)
    Even just starting out with nitrogen, topping up with regular air (mostly just my trusty bicycle pump), I see negligible air loss.
  13. Lee Jay
    5,850
    4,036
    Mine are Bridgestone Ecopia 422.
  14. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    I'm thinking it is the valve stems not the tires.
  15. Sam Spade
    2,036
    1,024
    2017 Prius c
    All time periods are not created equal.
    Wet air in tires will appear to lose more pressure in the fall months than dry air will in the spring........again because of temperature differences, not because of actual gas permeation.
  16. Sam Spade
    2,036
    1,024
    2017 Prius c
    Even more likely to be the tire seal against the rim.
