Nitrous-injected Prius Explodes
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Rebound, May 24, 2019.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Possible I suppose, but pretty hard to fake the dash warning lights....
    I'm not really leaning toward a lean condition. Lean conditions in N2O usually result in burned/melted pistons. I'm thinking more along the lines of mechanical failure due to too much instant rpm..way beyond what that 1.5 L engine/block/crank/rods are designed for.
    #21 TMR-JWAP, May 25, 2019
  2. Center of Gravity
    Center of Gravity Junior Member
    25
    New Orleans
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    N2O of course is laughing gas, and I think there may leak and someone got an over dose.
    Interesting though I wonder if you could fill tires with it as a heavy gas that does not leak...
  4. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    OK so you've got the pressurized oxidizer (nitrous oxide) and the fuel (rubber)... wonder how much heat you'd need? Now that would get some youtube clicks...
    #24 Leadfoot J. McCoalroller, May 25, 2019
  5. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ...another bad experiment perhaps
    I use a special heavy gas called STAFIL in my bike and Prius spare tire.
  6. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    Found it. Already on youtube.
    A big rubber log for fuel with nitrous injection to oxidize it.
  7. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    The N2O won't do anything until it breaks down under the heat of compression/ignition/etc. I think it's something like 500 degrees where the N2 separates from the O to allow the O to burn with the fuel.
    Now, if your car happens to catch on fire and burn on the side of the road one day, that may certainly make an interesting video when the tire start to burn. :eek:
  8. Mendel Leisk
    42,355
    Nitrogen fill tires purposely avoids Oxygen. It would be more aptly be called Oxygen-free fill. It's the Oxygen that leaks more, and causes corrosion.
  9. t_newt
    t_newt Active Member
    218
    247
    He actually says this himself in the video. The dumbest thing is that he did this right before his flight to Europe and his wife was already on her way to the airport without a cellphone.
    On the other hand disasters often get the most Youtube views, so maybe he knows what he is doing.
  10. Primo PEDRO
    Primo PEDRO New Member
    Seattle
    Does anyone know what kind of wheels he had? He didnt say in the video
  11. Protec
    Protec Junior Member
    33
    17
    Uk
    Hello,
    I have fitted several NOS systems to different vehicles.
    By far the best system I’ve come across uses “pulsoids” (basically the nitrous oxide and extra fuel is pulsed into the intake) one pulsoid for nitrous oxide and one for fuel. The whole system has corresponding jets, marked in horsepower increments. The better systems don’t just “arm” or “disarm”, they have a progressive controller, programmable options, like initial horsepower hit, for instance say 40% and a timed increase over .75second to full power. Also tank warmers etc
    It’s makes no difference how fast you think your car goes, it ALWAYS goes faster with NOS. Ask the dragracers.
  12. Protec
    33
    17
    Uk
    Forgot to say, the engine runs hotter than normal, use a colder graded plugs because he negative electrode is the first thing to start melting
  13. SnowMexicanuck
    56
    66
    Quebec, Canada
    What people forget to question is if the traction control was off or if the car was in maintenance mode to disable any kind of safeties. If you dump nitrous in and the computer kills the power, bad things will happens. You're supposed to have safeties so the nitrous system stops if anything happens (like hitting rev limiter and what not).
  14. Shahzad Nayyar
    Shahzad Nayyar Junior Member
    94
    25
    Pakistan
  15. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Hoovie has 1.2 million YouTube subscribers and makes $5,000 to $8,000 a month from his YouTube activity. His exploding Prius video got 1.2 million views.
    Hoovies Garage net worth, income and estimated earnings of Youtuber channel
  16. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You are arguing he is a professional shit for brains, rather than just naturally clueless?
    WilDavis, Grit and cnc97 like this.
  17. Rebound
    3,996
    2,645
    Portland, OR
    I’m arguing that he turned a profit from blowing up that engine.
