No “ready” light with no error codes
Discussion in 'Generation 1 Prius Discussion' started by beachdaman, Aug 27, 2019.
  1. beachdaman
    beachdaman New Member
    Los angeles
    2002 Prius
    Swapped a used hybrid battery ECU immobilizer and ignition into a 2002 prius. Car turns on but no “ready”. There are no error codes. I’m leaning towards inverter being bad since I don’t see inverter coolant pump moving liquid. I’ve checked fuses and battery is good.
    iPhone ?
    52,888
    wouldn't that be a bad pump?
  3. beachdaman
    Los angeles
    2002 Prius
    Yes, but I have had a prius run with a bad pump. It would start and then go into limp mode. I cant get the car to show “ready”
    iPhone ?
    52,888
    how bout the fuse?
  5. beachdaman
    Los angeles
    2002 Prius
    I checked them. Do you have a specific fuse/relay I should double check?
    iPhone ?
  6. mroberds
    mroberds Member
    143
    59
    2001 Prius
    By "immobilizer", do you mean the transponder key ECU? The factory service manual says that if you swap that ECU, you should do the following:
    1. Register the keys with the new ECU.
    2. Put one of the keys in the ignition, turn it ON, and leave it sit that way for 30 minutes.
    3. Turn the key to "start" and the engine should start.
    This is on page BE-103 of Volume 2 of the 2001 factory service manual. The pages around there have more information on how to learn in and unlearn the keys (most of which you can do without tools), etc.
    If you're looking at it on techinfo.toyota.com, the path is probably:
    Vehicle Interior > Body Electrical > Hybrid Vehicle Immobilizer System
    There is also:
    Vehicle Interior > Body Electrical > Hybrid Vehicle Immobiliser System
    with a few more pages from this section - note 's' instead of 'z'.
    #6 mroberds, Sep 14, 2019
