No acc radio dome lamp smart key -
Discussion in 'Gen 2 Prius Technical Discussion' started by Knightrider, Mar 12, 2019.
  1. Knightrider
    Knightrider Member
    150
    36
    Kansas
    I have replaced all fuses under hood and in drivers footwell w brand new fuses-lp
    Not one was blown.
    Is it possible the main 120a at the 12v has been the source of no accessories ?
    This is kind boggling
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    You post the end of something but what’s the beginning.....what happened?
    Not necessary to replace all the fuses just use a ohmeter and check every fuse with that but you can actually look in the fuse and see if it’s blown. If your concerned about the 120amp just get a voltmeter and measure the front jump point in the black plastic fuse box under the hood. If you have good 12 volts there your good you can forget about that battery and it’s fuses and connections.
    May I assume the car was jumped and the polarity reversed?
  3. Knightrider
    Knightrider Member
    150
    36
    Kansas
    No-
    I bought the car with a bad HV Battery
    I charged the 12v at 1amp to 14 and then rebuilt HV battery.
    Car does everything fine except display resets everynight- no stored ODO reading and I have no radio, dome lamps or Smart key.
    I have checked at jump point and have 12V and the replaceing fuses was purely to claim that I have all new fuses- no concern w a blown one.
    52,822
    two threads on the same subject can get confusing
