No Aircon A/C control after replacing HU
Discussion in 'Gen 2 Prius Audio and Electronics' started by Kiwibird, May 8, 2021.
  1. Kiwibird
    Kiwibird Junior Member
    56
    Sydney
    i-Tech
    I have replaced my head unit in my 2009 Prius, all functions work except the Aircon، outside temp, info, battery charging and fuel consumption screen not showing... If I put the OEM unit back everything back to normal, am I missing some adapter here? I know the radio functions won't integrate on the MFD that's fine but I need the other main functions!! How to solve this please??
    Thanks in advance.
  2. dolj
    dolj Senior Member
    8,622
    4,376
    Wellington, New Zealand
    There is a 68Ω resistor that is required to terminate the LAN bus correctly. Try and research that, if you don't have that resistor in place currently.
    Kiwibird likes this.
  3. Kiwibird
    56
    Sydney
    i-Tech
    dolji thanks for the help, I already ordered the resistor waiting for it to arrive, I have tried another Toyota genuine radio still the AC functions is not there as well as energy screen. Only the Prius radio makes everything work.
    I hope the resistor will fix the issue with the other none Prius head units.
    Thanks
  4. Kiwibird
    56
    Sydney
    i-Tech
    Ok I received the resistor, I connected a Toyota head unit from corolla 2005, the resistor did not change anything unfortunately, still displaying Check the connection of the AC... I am pretty I connected it right check photo.
    Thank you
