No audio from front speakers
Discussion in 'Prius c Audio and Electronics' started by TxMedic83, Jan 3, 2021.
  1. TxMedic83
    TxMedic83 Junior Member
    2014 Prius c
    I replaced a broken passenger side mirror today, and after the replacement, I have no front audio on my C.
    My front speakers are aftermarket. Checked the dome fuse and it’s fine, left the fuse out for a while to see if a powerless reset would fix it with no luck. Pulled the head unit and re-seated all the harnesses, with no change.
    When I move the fader to the front channels, I lose audio completely suggesting that only the rear speakers are putting out sound.
    Can anyone offer any troubleshooting suggestions? I can’t understand why both left and right front audio is out. This occurs in all modes, not just Bluetooth.
    Thanks!
  2. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    If the speakers are aftermarket then I'd immediately start by checking the wiring and connections at the speakers.
    You were working inside one of the doors, so there's a possibility of unintentional disruption.
    If you still have the head unit out, you can probe the front speaker lines with a meter- should tell you if the wires are connected, not shorted etc.
