NO AUDIO
Discussion in 'Gen 2 Prius Audio and Electronics' started by Knightrider, Mar 18, 2019.
  1. Knightrider
    Knightrider Member
    150
    36
    Kansas
    Since I revived a car that has sat 7 months w dead HV and low voltage 12v.
    I have been enjoying the car but fighting audio , dome and smart key issues.
    I am curious- replacing the radio- I noticed I have a 30A fuse underhood for AMP, but no physical amp under driver or pass seat.
    I don't see the wire harness under seats either- so was curious- was this an option for 04-05 that was just left in the fuse box?
    Anyone have a stock HU they want to let go cheap?
  2. Knightrider
    Knightrider Member
    150
    36
    Kansas
    Anyone had issues w Radio failure also taking the dome lamps out?
    I am about to swap the power distribution module out on the drivers footwell----
    The relays and fuses are all good including the two fuseable links.
  3. Knightrider
    Knightrider Member
    150
    36
    Kansas
    No one?
    Is there a possibility its turned off on the MFD- ?
  4. audiodave
    audiodave Active Member
    800
    272
    US
  5. Knightrider
    Knightrider Member
    150
    36
    Kansas
    Nope- zero dome lamp, smart key or radio function
    MFD says NO AUDIO
    I wondered is this setting I could change w diagnostic mode?
  6. audiodave
    800
    272
    US
  7. Knightrider
    Knightrider Member
    150
    36
    Kansas
    Ive replaced all fuses to make sure they were all in good shape
    Pulled and swapped relays in the cabin as well.
    I am curious I have an AMP fuse but no amp- and do not have the JBL HU
    anyone confirm their non- jbl has the fuse in the underhood.
  8. audiodave
    800
    272
    US
  9. audiodave
    800
    272
    US
  10. Knightrider
    Knightrider Member
    150
    36
    Kansas
    You know-
    I have been searching this for some time now-
    I am beginning to wonder if I have a failed mfd-
    I will open it up and see if I can see any broken solder joints
    Easily repaired if the case
  11. Knightrider
    Knightrider Member
    150
    36
    Kansas
    Underhood 30amp
    Number 45 is 30 amp fuse for amp
  12. Knightrider
    Knightrider Member
    150
    36
    Kansas
    Okay - needing some input
    I did the MFD diag and have Ncon for H/U and Chk on the MFD under Lan check.
    Any ideas?
    Think it's as simple as solder connections on the boards???
  13. audiodave
    800
    272
    US
    I don't know much about the MFD outside of caps going bad. But I do know if you replace your deck there's a special plug needed to make that work that comes with installation package. Like it puts power to the MFD.
  14. audiodave
    800
    272
    US
  15. Knightrider
    Knightrider Member
    150
    36
    Kansas
    Are you taking about the in-line 68ohm resistor we need to add?
  16. audiodave
    800
    272
    US
  17. Knightrider
    Knightrider Member
    150
    36
    Kansas
    I am okay adding that myself-
    I just need to check the solder on the MFD-
  18. audiodave
    800
    272
    US
    Did you change your deck?
  19. Knightrider
    Knightrider Member
    150
    36
    Kansas
    I will be upgrading-
    I have not swapped yet-
  20. Knightrider
    Knightrider Member
    150
    36
    Kansas
    Update: swapped Deck- no change. I do have all AC function - Still no audio - I will be tracing many wires before swapping Power Distribution or Body Control ECU
    I cannot understand why Toyota changed the wire colors in between junctions so often---- it's mind blowing.
