No battery warmer on my Prime
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Feb 2, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    well, it's official, there's no battery warmer on my Prime, it was 18 degrees last night and no sign that my battery was being warmed. The logging time was from 7:19 PM February 1, 2017 to 7:08 PM February 2, 2017 Prime charging status 2-2-2017.JPG
    bisco and thatoneraccoon like this.
  2. priuscatprimeguy
    2,730
    2,640
    I scheduled the charge time departure to 7:00 AM the reason it's at 1 amp is because I calibrated the clamp on ammeter to .94 amps.
  3. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    ive been wonder about battery and if its being heated at all in the super cold. I also wonder how much it going to affect range and life of battery. I picked mine up January 14th so its been cold since I got it for the most part. Cant wait to see what it will be like in the summer
    priuscatprimeguy likes this.
  4. priuscatprimeguy
    2,730
    2,640
    I also set the charge power to 8 amps
    thatoneraccoon likes this.
  5. thatoneraccoon
    201
    146
    Ohio
    I have a Clipper Creek 240 im using. I thought about getting the kit that hooks up in the breaker panel that can monitor amps on that breaker. however, the charger has a light on it if any power is being used and once the charge has completed, I have not noticed it reconnect. however, I could always maybe connect for a few minutes here and there, but at this time I dont know without that kit to hook up to my panel.
    hotelprisoner likes this.
  6. bisco
    52,855
    i would like clarification on this from someone @Prius Team .
    MikeDee and thatoneraccoon like this.
  7. huskers
    huskers Senior Member
    2,550
    2,488
    Nebraska
    Seems wrong to house your Primes out in the cold. Break down and get a garage.
  8. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Now there's a Carmane society ?
    Optimus PRIME likes this.
  9. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The "battery warmer" can be turned on and off in the vehicle settings. Check your vehicle settings. It may also affect charging time BTW.
  10. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    You don't know that.
    “Traction Battery Heater”
    When the outside temperature is low and the charging cable is connected
    to the vehicle, this function automatically warms the hybrid
    battery (traction battery) until it reaches or exceeds a certain temperature.
    You don't know what that "certain temperature" is.
    The OM has a circular set of references on how to turn it off, but it does say:
    “Traction Battery Heater” can be turned on and off in the “Vehicle Settings”
    settings on the multi-information display.
  11. bisco
    52,855
    maybe it comes on at -100f.
  12. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    Yup ... you can find the Setting here:
    jump to 0:40 on my video for reference:
  13. bisco
    52,855
    am i confusing climate prep with battery conditioning?
  14. David Beale
    5,963
    1,990
    Edmonton Alberta
    It's "Prime speak" in the manual. You have to read -carefully-. I got bitten once already and am "shy". ;)
  15. Lee Jay
    5,850
    4,036
    Look in the video at 1:01.
  16. Prius Team
    Prius Team Toyota Marketing USA
    681
    1,817
    CA
    The battery warmer needs the vehicle to be plugged in in order to operate, could that be the issue?
  17. bisco
    52,855
    thanks. i saw it, did optimus skip right by it?
  18. Lee Jay
    5,850
    4,036
    Since the plot in the OP is of a charge, including positive charge current, it must have been plugged in.
  19. bisco
    52,855
    i'm not sure what is at 40, but at 1:00, i see traction battery heater?
  20. Prius Team
    681
    1,817
    CA
    True enough. That's very odd - @priuscatprimeguy, can you send me a direct message so we can have someone from CEC give you a call?
