No Bluetooth with Ground Loop Noise Isolator Connected
Discussion in 'Gen 2 Prius Main Forum' started by jrdamien, Sep 8, 2021.
  1. jrdamien
    jrdamien Junior Member
    57
    Minneapolis
    Has anyone had this problem? It's driving me insane. I have a Bluetooth 'disc', the BTC450. I've had it for years. When I connect any ground loop noise isolator the bluetooth kit won't even power on.
    I had this issue when I originally set it up but that was 7 years ago. Recently someone broke in and stole everything except the bluetooth, which still works, but which has noise via the AUX connection. I don't remember the solution but recall I read the solution here (but can no longer find it).
    Thanks!
  2. burrito
    burrito Active Member
    274
    114
    Perhaps it's designed to not turn on if it doesn't detect a signal. In that case, maybe the noise isolator is dampening the signal too much?
    You're sure the noise isolator works fine in other applications?
  3. jrdamien
    57
    Minneapolis
    It works in other vehicles. But not in the '09 Prius.
  4. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    If you end up not solving the problem, I’d recommend this for $40
  5. jrdamien
    57
    Minneapolis
    You'd recommend what?
  6. burrito
    274
    114
    Search for B01HDO66NK on Amazon. It didn't show up for you because you're using an ad blocker.
  7. jrdamien
    57
    Minneapolis
    I have a 2nd Gen Prius. Where does the USB go?
  8. burrito
    274
    114
    I just looked at the item. I suspect the USB is only for power. If you don't have a USB port nearby, you'd have to figure out some kind of extension. You could possibly MacGyver your own power supply by splicing into nearby wiring. If you're going to do that, there are cheaper options out there.
  9. jrdamien
    57
    Minneapolis
    I'm not going to do that. I'm just trying to solve the issue as it stands.
  10. Another
    1,819
    520
    Naples, Florida
    Seems there may be some confusion on what this simple device does.
    The device I cited is a simple Bluetooth receiver that has two connections. The first is a USB for Power, the second is an audio cable.
    It works in Gen 2 Prius’s by locating it in the center console right next to the cigarette lighter power socket and the AUX in audio port,
    You also need, if you don’t already have one, a simple cheap $5 USB cigarette lighter plug adapter that provides 5v to the USB.
    This device is tiny and works flawlessly by cooperating and working independently of the cellphone Bluetooth system in the Prius.
    It has a very very high quality audio using an LDAC and ground loop noise elimination circuit.
    It automatically pairs with your phone and in fact also another phone simultaneously upon power up of the car if you want two people to be able to share audio to the Prius.
    There is no other wiring required. No MacGyvering. Just connect in the console to the AUX and USB power with included short cables.
    The reason I brought it up here was because the OP was having ground loop audio noise problems. It is definitely NOT too complicated to use. It may however not be what the OP wants to use.
  11. jrdamien
    57
    Minneapolis
    This is kind of post hijacking at this point, right? The post isn't about this very specific BT adapter.
  12. Another
    1,819
    520
    Naples, Florida
    Hijacking? Get real.
    I was responding directly to a posting that implied complexity of using the device.
  13. jrdamien
    57
    Minneapolis
    This is as real as it gets. The post was never about device recommendations or the complexity of that device.
  14. Another
    1,819
    520
    Naples, Florida
    Your comment is ridiculous
  15. dolj
    dolj Senior Member
    8,644
    4,393
    Wellington, New Zealand
    Regardless of what you think, he is the original poster of this thread, so you need to respect his moderation.
  16. jrdamien
    57
    Minneapolis
    I'm not being disrespectful of anyone. I asked a technical question and the post became about a device recommendation. THAT is disrespectful.
    They could just make a post saying what an awesome BT kit it is.
  17. dolj
    dolj Senior Member
    8,644
    4,393
    My post was not directed at you as the OP (original poster). It was a post in support of your position to moderate your post. Your post was quoted just to provide context.
    jrdamien likes this.
  18. jrdamien
    57
    Minneapolis
    If anyone ends up with a similar problem, here is the kit I bought that works good for audio and phone. I tried 3 different ground loop isolators that all had the same problem. This works very well.
