No catalyzer + faulty o2 sensor
Discussion in 'Gen 2 Prius Fuel Economy' started by Hakam, Jul 31, 2022.
  1. Hakam
    Hakam Junior Member
    Jordan, Amman
    So i bought this used 2008 prius but i am only getting max 25mpg wich means that each pip goes around 17 miles. I diagnosed it in a workship and no catalytic convertor was there + the o2 sensor needs cleaning. Now some expert told me that first i should but a calatic convertor because it might fix the problem since the o2 sensor is connected to it. The thing is that it is way too expensive so i am planning to buy a copy version of it. Do you think the getting a catalyzer will fix my mileage problem? If not should I put o2 sensors on my top priority?.
  2. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    Or just replace the sensor and put a straight pipe in place of the missing converter
    Options after a CAT theft | PriusChat
  3. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    52,854
    how many km on her? maybe the engine and battery need work
  5. Hakam
    Hakam Junior Member
    Jordan, Amman
    Engine is new and the battery has 2 faulty cells. Despite that, i am only getting 22mpg
  6. bisco
    52,854
    are any of the brakes dragging?
    Prius Rising likes this.
  7. Boblay
    Boblay Junior Member
    Good question
  8. Hakam
    Hakam Junior Member
    Jordan, Amman
    No. But my abs system isn't working
  9. Another
    1,819
    520
    Naples, Florida
    How do you know (only) two cells are faulty?
  10. Hakam
    Hakam Junior Member
    Jordan, Amman
    It undergone a battery check in a car shop
  11. bisco
    52,854
    must be the catylizer and the o2 sensor then
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    The hybrid battery modules are in series so only takes one failing module to kill the whole pack.
    you have poor mileage because your hybrid battery is bad. Hybrid battery supply’s most of the power in a Prius.
  13. Another
    1,819
    520
    Naples, Florida
    May want to download Dr Prius app and get more info yourself as you drive. Even the free version is useful.
