No charging cable ?
Discussion in 'Prime Plug-in Charging' started by Marine Ray, Apr 18, 2022.
  1. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Isn't the only difference between Toyota's L1 ans L2 EVSEs the NEMA plug used? as @bisco mentioned above in post #16 .
    I don't see the issue, since there is still a ton of speculation .
    52,891
    what does "a standard connection for L1 and L2" mean? my pip has that, doesn't it?
  3. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Ugh. I didn't. I said standard connection. And now I will spell it out to be concise...
    SAE J1772
    SAE J1772
    SAE J1772
    SAE J1772
    SAE J1772
    Clear now?
    Tideland Prius likes this.
    52,891
  5. vvillovv
    4,337
    1,519
    NY
    All I can see from here is a Wall
    or another brick
    it wouldn't come with both DC-fast and J1772 - could it?
    Like the reports of Prius Alpha in Japan.
    #25 vvillovv, Apr 22, 2022
  6. Tideland Prius
    16,683
    Much better. :)
  7. john1701a
    12,840
    5,312
    58
    Can you tell I'm frustrated by our lack of progress on that front?
    I had really hoped to find that connection so common at this point, we could shift focus to DCFC. Instead, there are few to be found.
    That is changing. Up north where we vacation, a few public chargers have finally appeared. My wife's Prime will have to do those trips. The 4X will be waiting for CCS to spread. So far, there are more unicorns.
  8. Tideland Prius
    16,683
    Yeah we really need more DCFCs for road tripping. If manufacturers like Toyota aren’t planning on putting higher powered onboard chargers, then we’re stuck with cars taking 40-60 mins to reach 80%, so we’ll have to deal with longer wait times on busy weekends.
  9. john1701a
    12,840
    5,312
    58
    At least we'll be getting a BEV system that's decent in terms of efficiency. After all, there are 30 states that now offer per-kWh pricing rather than per-minute at DCFC. That means the amount of electricity itself needed to recharge makes a difference, while away and at home.
    Since I have my sight set on AWD, that's the numbers I researched with regard to similar size & price vehicles:
    93. MPGe combined = 36 kWh/100mi = 2.76 mi/kWh = AWD Ford Mach-E
    94. MPGe combined = 36 kWh/100mi = 2.79 mi/kWh = AWD Toyota RAV4 Prime
    98. MPGe combined = 34 kWh/100mi = 2.91 mi/kWh = AWD Hyundai Ioniq 5
    101 MPGe combined = 33 kWh/100mi = 3.00 mi/kWh = AWD VW ID.4
    102 MPGe combined = 33 kWh/100mi = 3.03 mi/kWh = AWD Toyota bZ4X Limited
    104 MPGe combined = 32 kWh/100mi = 3.09 mi/kWh = AWD Toyota bZ4X XLE
    105 MPGe combined = 32 kWh/100mi = 3.12 mi/kWh = AWD Kia EV6
    131 MPGe combined = 26 kWh/100mi = 3.89 mi/kWh = AWD Tesla Model 3 LR
    For perspective, if you are driving a Prius Prime with only electricity, it tops all those examples:
    133 MPGe combined = 25 kWh/100mi = 3.95 mi/kWh = Toyota Prius Prime
    #29 john1701a, Apr 23, 2022
  10. CharlesH
    2,798
    1,166
    Roseville, CA
    Why are the BEVs all less efficient (kWh/100miles) than the Prime? Is their approach to just toss in a bigger battery? Like the auto manufacturers just tossed in a bigger gas tank years ago.
  11. bisco
    52,891
    i think so. to sell any appreciable amount in the current environment, you have to appeal to more than efficiency.
    that's the last thing on most american consumers minds
  12. vvillovv
    4,337
    1,519
    NY
    going way to the end of the tree branch with this comment, bigger, heavier and higher cars that need to go 0 to 60 under under 5 seconds.
    john1701a likes this.
  13. bisco
    52,891
    going to need much higher if you live near the coasts
    vvillovv likes this.
  14. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Yup! Huge vehicle with a huge battery adding up to a tremendous amount of weight to get moving and keep moving along with tons of air to push aside. And then there's all the inertia needed to get those heavy 20" wheels spinning.
    I've been lusting after the Ioniq 5 but may wait for the Ioniq 6, which will be smaller and should be more efficient.
    And then there's my Prime (and many like it). My lifetime average is 5.1 miles/kWh. Most of my driving routes these days are 5.7-6.0 miles/kWh with speed limits mostly 45-50 mph. :D
  15. Tideland Prius
    16,683
    Because they’re heavier and are SUVs. Note the Model 3 sedan gets better kWh/100 miles.
    I suspect the Ioniq6 will be up there since it’s a low slung sedan.
    The larger wheels are needed for ground clearance since BEVs have the batteries beneath the cabin. On an SUV with higher ground clearance, you can use a smaller wheel since the suspension is raised anyway. On a sedan or Hatchback, they may resort to larger wheels to gain that 1/2-1” additional ground clearance needed without making the car look like an Outback Sedan.
    jerrymildred likes this.
  16. vvillovv
    4,337
    1,519
    NY
    They might want to call the extra high models King Tide trims or equip them with a floating suspension so they can be docked in or to the side of the garage..
    #36 vvillovv, Apr 24, 2022
  17. bisco
    52,891
    could be what's holding up the next gen :cool:
  18. vvillovv
    4,337
    1,519
    NY
    could be !! But if it is, we'll probably not hear about it anytime soon......
