NO Codes No Start No Ready
Discussion in 'Gen 2 Prius Technical Discussion' started by NortTexSalv04Prius, Dec 1, 2018.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
    2007 Prius Gen 2
    No readable OBD2 Codes
    No Green Ready dash light
    No blown fuses found under dash or engine compartment
    Many other dash lights are visible though VSC,ABS, Red Triangle of Doom, fuel level indication
    Voltage drop in 12 volt battery detected however above conditions still present after 12volt battery charger complete cycle and maint cycle
    On power up sequence
    Key fob insert
    first push on dash start button gets green dot
    second push start button combine with brake pedal pressure
    No MFD
    High voltage contact does not "sound" like making full latching cycle
    In advance thanks for all help
  2. ChapmanF
    19,020
    Shouldn't even take that many steps ... key fob insert, step on brake, push button one time, READY.
    Are the brake lights in back glowing when you step on the brake?
    NortTexSalv04Prius likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Orange safety plug is inserted correctly and the fuse inside of that is good?
    52,849
    measure the 12v, don't trust the charger
  5. JC91006
    16,936
    8,647
    I second the safety plug. Flip up and then push downward to lock. Many people miss the push down to lock part
  6. bisco
    52,849
    did you pull the hybrid battery?
  7. NortTexSalv04Prius
    915
    116
    Currently in lock position and has not been disconnected in recent past
  8. NortTexSalv04Prius
    915
    116
    That is a NO
    Vehicle was driven on Thrusday
  9. bisco
    52,849
    so the orange interlock would be intact?
  10. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    And the fuse inside of the orange plug is in good sorts;)?
  11. NortTexSalv04Prius
    915
    116
    Did that already 12.8V
    will recheck voltage again though since found at 8.2V
    brand new battery charger
    #11 NortTexSalv04Prius, Dec 1, 2018
  12. NortTexSalv04Prius
    915
    116
    will check that
    Raytheeagle likes this.
  13. NortTexSalv04Prius
    915
    116
    Yes on both
  14. NortTexSalv04Prius
    915
    116
    No
  15. strawbrad
    953
    1,007
    Just a WAG. Blown AM2 fuse caused by a shorted inverter coolant pump.
  16. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Which OBD2 code reader are you currently using?
  17. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    C'mon man you have been here a long time you know we need the codes. Of course there readable you just need a techstream capable OBD reader.
    Good 12 volt won't start usually in hi voltage ground fault lock out. Disconnect the main 12 volt lead by unclicking its white connector at the battery positive terminal black fuse assy and wait 30 seconds and plug it back in.
    if not that you need codes pulled.
    JC91006 likes this.
  18. NortTexSalv04Prius
    915
    116
    Which do you suggest
  19. NortTexSalv04Prius
    915
    116
    Please expand I am unfamiliar with WAG
    Just so I am sure the AM2 fuse is the one encased in the orange safety plug
    FYI
    A couple of thoughts ….. I have seen another thread where Gen 2 has the following conditions/issues..... failed coolant pump....No MFD..
  20. NortTexSalv04Prius
    915
    116
    You are probably correct on following
    Need access to techstream OBD2
    However SG2 has yet to fail me
