NO Codes No Start No Ready
Discussion in 'Gen 2 Prius Technical Discussion' started by NortTexSalv04Prius, Dec 1, 2018.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
    YES
  2. NortTexSalv04Prius
    915
    116
    Questions
    Are you suggesting and or am I understanding that maybe replacing the following:
    Inverter pump
    HV fuse encased in orange plug
  3. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    A mini-vci cable (or compatible) and a copy of techstream.
    Raytheeagle likes this.
  4. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    My WAG would be a 'wild a$$ guess', those his may differ ;)
    Samuel Williams Jr likes this.
  5. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Disconnect the ICP (inverter coolant pump), then replace the AM2 fuse. You can replace the pump after you're sure that is the problem. If you don't first disconnect (or replace) the pump before replacing the AM2 fuse, then the fuse will blow again.
    The AM2 fuse is "#31 AM2 15 amp “IGN” fuse, ignition system", it should be labeled on the inside of the engine fuse box cover.
    Best to just pull and post the codes here.
    strawbrad and Raytheeagle like this.
  6. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    You stated having many dash lights illuminated (including the "Red Triangle of Doom"), my WAG is it has finally failed you :whistle:
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    I have a SG2/Xgauge it doesn't pull comprehensive hybrid codes.
    I have the mini vci but it was a cranky install. I primarily use the VXDIAG OBD Tester Amazon.com $77. Full Techstream.
    Includes the OBD dongle you just plug the little box into the obd port and then its USB into a laptop.
    I don't use my good Win10 laptop I use a old Dell XP burner laptop.
  8. NortTexSalv04Prius
    915
    116
    Okay now WAG TAG and BAG wild, tall, and bad guess really not the path I want to go.... All fuses are currently known good in engine compartment …..
  9. NortTexSalv04Prius
    915
    116
    Yes the instrument cluster shows VSC,ABS, red triangle,etc
    WAG what is it????????????
  10. NortTexSalv04Prius
    915
    116
    oh yeah coolant pump link not close match replacement
  11. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Without any OBD2 codes, guessing is all one can do at this point.. be it WAG TAG or BAG o_O
  12. bisco
    52,854
    Wild A$$ Guess
  13. NortTexSalv04Prius
    915
    116
    Okay you are the DUDE...
    Thank you for the direction BISCO
    Follow Up
    Winter time and 12v lead acid voltage drops apparently on group 51 wally world everstart battery....Initial charge and charger did not reveal and discharge battery of 8v which still has not recover …..so problem solved
    SFO and bisco like this.
  14. bisco
    52,854
    congrats!(y) i always wanted to be a dude.:cool:
  15. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    But not to the @grid level of “my dude” :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:.
  16. Martinsanr
    Martinsanr Junior Member
    San Diego
    SAme problem on 2005 prius. No codes, No ready light, no start. Just found out the STOP fuse was blown. Just replaced fuse and prius is on the road again. It is the fuse number 9 located in the fuse box near the pedal brake. Hope this help someone.
    Cometflash likes this.
  17. ChapmanF
    19,020
    Have you found out why the fuse blew yet?
