No coolant meter
Discussion in 'Prius c Main Forum' started by Boojoo007, Sep 30, 2012.
  1. Boojoo007
    Boojoo007 Junior Member
    64
    There is no coolant meter! There is only an icon that appears if I'm already over heating.
    Kind of a bummer, I would like to monitor this manually but maybe it's not necessary.
    Just kind of scary.
  2. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
  3. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    I too think it a good idea to monitor the temp of the coolant. A ScanGauge, as mentioned, is great. I am using the 60 dollar Ultra Gauge in the C. Works great and has lots of "metering" capabilities.
    Dan
  4. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Inverter temp is more critical than the ICE's coolant temp. Monitor both. Many if not most cars don't have gauges. Idiot lights are cheaper.
  5. DKTVAV
    DKTVAV Active Member
    510
    101
    $60 vs. $160: where did you buy Ultra Gauge? Is it good enough compared to Scan Gauge II/E?
  6. WD0AFQ
    619
    152
    Dexter, Mo.
    I think the only place to get it is direct from them. It was 69 dollars with a 9 dollar rebate once you fill out their questionaire, on line. I have both gauges. The Ultra Gauge is not as good as the ScanGauge, in my opinion, but there is a huge price difference. Yes, it is "good enough". Especially for the price, a real bargain.
    Dan
  7. RocMills
    RocMills Active Member
    789
    276
    Las Vegas, Nevada
    Hmmm... I like the look of that UltraGauge. It would be more of an informational "toy" for me, not a necessity. I seem to be putting together quite a list of goodies for the PC2 should I ever win the lottery.
    Rob.au and Tracy like this.
  8. garylow
    garylow Junior Member
    16
    new jersey
    why is ultragauge not as good?
  9. garylow
    16
    new jersey
    curious why the scanguage is better than ultragauge. Just bought the scangauge when it was on sale on amazon for $125. Works great, but I like that more gauges show at one time on the ultragauge. Might buy one for my wife's minivan.
  10. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Does the Ultra-gauge provide all of the Prius specific gauges like the Scangauge does with its Xgauges? Can you clear codes or just scan for them?
  11. WD0AFQ
    619
    152
    Dexter, Mo.
    Yes you can clear them. If you like more gauges showing the ultragauge is for you. They both have good points. I like scangauge due to its simplicity of set up and operation. The ultragauge is more complex and requires some serious reading to set up and operate. I have both mounted at present and the scangauge plugged in. It seems more accurate on instant mileage but i may not have had the ultragauge set up exactly right. I will read up more on it before running it again. That was great buy for 125. I just saw an older used one on ebay go for same price. I had mine out to sell but changed my mind. I like both of them.
    Dan
    F8L likes this.
  12. CMJAnew
    CMJAnew Junior Member
    87
    17
    Do both of the gauges mentioned in this thread monitor the Inverter Temp?
  13. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    According to their website, UltraGauge currently does not support Manufacturer specific gauges such as Transmission temperature.
    Vincent
    F8L likes this.
  14. vincent1449p
    894
    331
    Singapore
    Hi CMJAnew,
    UG cannot display Inverter Temp, only the SGII with Xgauges can. See my post on the list of Xgauges.
    Vincent
  15. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    I personally use my Android smart phone with the Torque app hooked up to a $10 bluetooth obd2 device. Works great. If you pay for the $5 paid app you get all kinds of meters to read and be distracted. :LOL:
  16. col127
    col127 Member
    345
    Illinois
    Does that show you all the stuff that ScanGauage does? If so, that's a way better option and I'm going to do it! I would love to see some of the stuff ScanGauage shows but I'm too cheap to buy one :)
  17. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Not sure what all ScanGuage shows, but if you are interested in a certain gauge let me know and I'll tell you if it has it. Note: I haven't installed any custom PIDs and I get a lot of information. From what I have read I could get a lot of the electric information if I install the custom ones... which I have also read is rather easy, just haven't had the time.
  18. col127
    col127 Member
    345
    Illinois
    Does it measure Inverter coolant temperature? I put grill blocking on my C and want to make sure it's not getting too hot inside :)
  19. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    That might be one of those electrical ones that I'm not sure about, but I do know that you can see coolant temperature.
  20. WD0AFQ
    619
    152
    Dexter, Mo.
    What would be a cheap Android phone to look out for? I only have Iphones.
    I took my Ultra Gauge out and only use the ScanGauge now. That Ultra Gauge is a nice unit for the price but more complicated to set up than the ScanGauge. Guess it may be for sale.
    Dan
