No cruise control
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by priusrick, Aug 16, 2016.
  1. priusrick
    priusrick Member
    257
    40
    My cruise control all of a sudden stopped working today. Any thoughts?
    SGH-M919N ?
    Paulhutchi likes this.
  2. JC91006
    16,845
    8,613
    brake switch malfunction
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    CC does not work in B. Any chance you accidentally shifted to B?
    Higgins909 likes this.
  4. priusrick
    priusrick Member
    257
    40
    Nope, I've been driving all day with this situation
    SGH-M919N ?
  5. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    Cruise light turn on when button pushed?
  6. priusrick
    priusrick Member
    257
    40
    No
    SGH-M919N ?
  7. priusrick
    priusrick Member
    257
    40
    Nope, it's clearly in drive
    SGH-M919N ?
  8. Jimi1976
    242
    124
    Denver, CO
    Could be a defective on/off switch on the stalk.
    Worth a $20 replacement, if you're up for it.
  9. Paulhutchi
    Paulhutchi New Member
    Cape Town, South Africa
    all I'm new here. I find when I turn on my cruise control, it will turn on and I can set it to speed. As soon as I break and try to use it again, I then notice that the cruise control light blinks slowly in an orange color.
    Does this mean the brake switch malfunction or the cruise control is acting up?
  10. JC91006
    16,845
    8,613
    If the car has been in an accident before and the spiral cable was replaced, that's usually the problem...The cable
  11. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    Techstream will tell you if the stalk cruise switch is engaging or not. Don’t go all out and replace the stalk and find out that wasn’t the problem.
  12. Frijjj
    Frijjj Member
    66
    35
    Runcorn, UK
    I think my car has a replacement wheel, is the spiral cable part of the clock spring?
    How can you tell with Techstream? Is it an error code for the stalk?
    Sorry to bump an old thread but it's the closest to my issue that I've found
  13. Kevinmatth
    Kevinmatth Junior Member
    Alabama
    The cruise control stopped working a long time ago. After I replaced the ABS actuator and hooked up the computer to bleed the brakes and reset all the codes, the cruise control started working again. The cruise control has now stopped working again. Any idea why this would happen?
  14. ChapmanF
    18,632
    Use the trouble codes to diagnose; if there are no codes (using a scan tool known able to show them), watch the live data list while working the stalk and button and brake pedal, and see what signal isn't getting through. Ought to be fairly straightforward.
