No Dash Display after replacing Aux Battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chiriqui, Oct 20, 2020.
  1. chiriqui
    chiriqui Junior Member
    17
    I Installed a new auxillary battery in my 2004 Prius
    No dash board display?
    To open the trunk i jumped the car with the new battery at at that time I had a dash board display and no engine warning yellow icon
    What has happened?
    Car seems to operate normally as far as I can tell
    I checked the menu on the display and the new battery shows 13.4 volts
    Can I reset the computer? Could that be the fix?
    #1 chiriqui, Oct 20, 2020
  2. chiriqui
    17
    I installed a new auxillary battery.
    Prior I jumped the car to open the hatch using the jumper box under the front hood. At thst stage I had a dash display.
    Briefly I had a main battery red alert and a check engine light that stayed on.
    That isnt the case now but still no dash board display?
    Is it possible to reset the computer?I have been into the menu by holding the display button and turning the lights on/off 3 times. The new batteey reads 13.4 volts
    Suggestions. A dealership with limited experience on a Prius is an hour away.. I'm in tje Republic of Panama
    52,883
    13.4 is pretty high, is the car off?
    52,883
    we're in gen4 forum, can i assume 2004?
  5. chiriqui
    17
    Solution
    pghyndman likes this.
  6. chiriqui
    17
    Solution
    PS yes I thought 13.4 seemed high. The battery I think a delco said it was for my Prius 2004
    krmcg likes this.
  7. bisco
    52,883
    so, it's the combo meter?
