No electric in COLD WEATHER ONLY
Discussion in 'Gen 2 Prius Main Forum' started by P08A80, Jan 26, 2021.
  1. P08A80
    P08A80 Junior Member
    22
    Fremont, CA
    My Prius has a strange problem. I can't start the car whenever it snows. But when the snow melts and the weather warms up a little, I can start the car fine without jumpstarting it. What in the world is going on?
    There are no lights on the dash. Headlights can't turn on. It has all the symptoms of a dead battery, but the battery comes back to life when the temperature goes up without any jumpstarting. Is this normal?
  2. davecook89t
    davecook89t Senior Member
    1,093
    832
    Washington State, Florida
    Certainly a battery's power is reduced in colder weather, but how cold are we talking here? Unless the temperatures are sub-zero, the reduction in capacity would not be significant. Your battery could be weak, but are you really saying you see no light at all coming from your headlights when you turn them on without the car in Ready mode? My best guess would be that you have a loose connection between your cables and the battery or between the negative cable and ground. Possibly the connection becomes slightly better in warmer weather with thermal expansion, although at best I would say your connection is probably unreliable in any kind of weather. The connections to the battery in the rear is where I would look first, and then put a multi-meter on your front jump points to see what voltage you get. It should be 12.5V or better.
  3. P08A80
    22
    Fremont, CA
    Roughly 25 degrees with snow. No signs of electric at all, no blinking dashboard lights, car won't start, no headlight or lights inside. When warm weather rolls around (35 degrees and snow melts), the car starts. Happened a couple times already.
    That's a good idea to test the battery with a multi-meter. Thanks.
    In the case it's a connection problem, any idea what the possible connections to look for are?
    davecook89t likes this.
  4. PriusCamper
    PriusCamper Senior Member
    13,466
    5,433
    Pacific Northwest, USA
    If you have a really old 12v and you live in a warm coastal area like Fremont, CA., it makes sense that it's finally gonna go bad when you take it up into the mountains where it's much colder and you're lucky it works at all after it warms up a bit.
    It's time for a new 12v battery. Let us know if you need help deciding on what kind to buy.
  5. Leadfoot J. McCoalroller
    8,289
    7,803
    Pennsylvania
    2018 Prius c
    If the connections on your 12v battery are not tight, thermal expansion can be the trigger between conductivity and non-conductivity.
    Inspect and tighten the connections at the 12v battery posts.
    A fully charged AGM battery should be showing around 12.85 volts. Lead-acid would be closer to 12.6 when full. I think your version of the car has AGM but doublecheck.
    PriusCamper and davecook89t like this.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    "Normal", not quite.
    "Common" yes absolutely.
    You have a bad 12 V main power connection somewhere, maybe INSIDE the battery.
    You need a voltmeter to do some testing while it is failing.
    In the mean time, check the battery cables where they connect to the posts.
  7. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    How old is the lead acid battery ? The average lifespan is 5 years, and it's like they have a $@#!!## built in timer.
    If the battery is 4+ years old, replace it..
    jp
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    The 12 volt battery well may be full of water too. Many a Prius has bad cabin leak. if the car lives outside drill a drip hole in the rubber plug in that battery well.
    don’t remove the plug it may present a lovely hole for mice to get into the car mice love a G2.
    lots of people on other car forums report mice chewing on wiring so becoming
    A common issue.
  9. PriusCamper
    13,466
    5,433
    you'd have to be a really skinny mouse to get through a 3/8" drain plug hole...
  10. qmanqman
    qmanqman Active Member
    444
    153
    CO
    Hmmm . . . my daughter has made mention something similar to this since winter began. We also replaced her OE battery this past fall. Sucker was a 2007 battery.
    The first time she mentioned it she called me to tell me her car wouldn't start. She said pushing the "Power" button started the engine but the dash remained turned off. She pressed the "Power" button a few more times and it was all normal. Then a week or so ago she said that sometimes her car won't start (not sure exactly what "won't start" means) when its cold. I'll have to check the battery connections once more.
