No electric torque
Discussion in 'Gen 2 Prius Technical Discussion' started by arniesalsared, Sep 24, 2012.
  1. arniesalsared
    arniesalsared Junior Member
    Phoenix, AZ
    It's a hot 110 degree day in my 08, we have 5 in the family. Parked for three hours and on return starts up normally. Noticed low torque and slow acceleration on take off. Got on the freeway and slowly got up to 65MPH with obviously only the ICE working.
    Used the reader and no codes?? Next morning all normal again?? Software glitch?
    Has anyone seen this one?
  2. uart
    uart Senior Member
    4,220
    1,211
    Australia
    I think it's just the temperature of the batteries, if the pack is too hot then it tries to use less electric power.
    After you stop the car, there may still be some heat coming out of the battery pack, so the battery temperature can continue to rise even after you park. Then with it sitting in the heat I think that the battery gets a little too hot. After you start to drive the battery gets more air circulation and eventually cools enough to start performing properly again.
