NO fix for Prius Gas Tank Filling Up Issues
Discussion in 'Gen 2 Prius Main Forum' started by dar, Jun 16, 2008.
  1. keith_w
    keith_w New Member
    Los Angeles, CA, USA
    Sorry this reply is late, but...
    North American model?
    I bought my '07 Prius in Southern California, and have once filled it with 11.9 gallons! I think i WAS on fumes by then, and very lucky!
    I guess I have a bladderless gas tank?
  2. john_dough
    john_dough New Member
    75
    pkarsh--I share your pain. I believe that the debate on this site as to whether or not this is a design flaw is largely a distraction by those few who are committed to defending Prius for their own interests. As to "Whom do you write to at Toyota", I've heard that there are websites where one can craft and implement a petition. Perhaps one of the more computer literate among us will explore this approach. I understand it has worked with Toyota in the past on other problems.
  3. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    I don't know who "those few" would be, or what "their own interests"
    would be. The vast majority of us are stakeholders as owners, and
    therefore current or future victims.
    It does seem the community of Prii owners is divided into have's and have
    nots on this issue. I haven't yet had this problem... but it is a lingering
    concern. I don't consider my car as permanently immune to it ever
    happening... it's just a matter of when and of greater concern thereafter,
    will it continue into the future.
    I wonder, does this mean that I am numbered among "those few who are
    committed to defending Toyota for their own interests?"
    The condition seems to be randomly distributed... but I wonder if there's
    some obscure event(s) or condition(s) that predispose or cause this
    problem. While I can speculate on possible such conditions, I don't know
    how it could ever be verified that they are actual causes.
    Conditions leading to a twisted of folded bladder that causes permanent
    restriction or reduction in volume might include:
    * Before being sold, sitting for a long time with the tank nearly empty.
    * Before being sold, sitting in very high, or low temps.
    * The first fill up by the dealer being done too fast, or too slow.
    A while back, one poster -- Jayman? jhinton? Shawn_Clark? -- briefly
    mentioned a form of statistical or data analysis used first by NV casinos
    and now by Homeland Security folks that is able to find connections
    between apparently unrelated data. I suspect that it will take a very
    sophisticated and costly analysis like this to identify the real issue here.
    Toyota itself is the only entity that would have access to the data
    needed.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    No, all North American models have the bladder. What you had was a very empty tank that was then overfilled. Just as with a normal tank, you can overfill the Prius tank and add a little extra up the filler pipe and vent. It's not a good thing to do.
    Tom
  5. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    For the people having problems fueling, please say whether you are following the nozzle position diagram on your station's pump. Hopefully they have one.
    6th fillup this morning with no problems.
    I just lay the nozzle into the filler neck so it's secure, but not too far in, let handle rest, pull trigger, set on highest pump setting, watch and hope, one click off, done.
    Power up, reset meters, 10 full bars on gage, drive off.
    42 F this morning.
    >>> The first fillup, I stuffed the nozzle far in, held the handle and lever, pump clicked off repeatedly <<<
  6. FBear
    FBear Senior Member
    355
    23
    Maplewood, NJ
    2015 Prius v wagon
    I don't know what all the bitching is about. Fill it up and drive. Not safe for long distances. What are you out of your mind. You will always have enough to drive a few hundred miles and then when there is two pips, fill it up again and drive. The fact that you can't get 11.9 gallons in is no big deal. You are getting the same mileage whether you have 11.9 gallons in the tank or you have 9 gallons.
  7. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I filled up at 2 pips, pumped in about 7 gallons after 300 miles. Works for me.
    * note - I used fast pump setting this time (tends to get little more gas in) and slow setting last time, so MPG figure above not accurate.
  8. Navigator
    Navigator New Member
    22
    Fullerton, CA
    This is how I do it, too. I just keep an eye on the pump. If I'm filling at 2 pips, and then the pump goes toward 9 gallons, I going to click it off. When the pump clicks off on its own, then I'm done. No games; no problems.
  9. Navigator
    22
    Fullerton, CA
    I feel exactly the same way. Never before have I or anyone I know had such feelings of apprehension about filling up a vehicle or fuel container.:eek: Okay, except for when filling with diesel, because diesel can get foamy which makes it a chore to get a truly full tank. But other than that . . .
  10. hill
    8,807
    Dar,
    You are complaining because you can "only put 6 to 10 gallons in it". So if you had 2 gallons in it, then your fuel gauge still shows full? That's what mine shows & I've NEVER put 10 gallons it it, except once ... when the pip had been flashing for over 30 miles. So you average 8 gallons per fill? That's not so horrible. That's still roughly 350 miles before the last pip will be flashing. BTW, THAT's how you'll know when you're low on fuel ... the guage will read only one pip ... after that it flashes. Nothing special. You don't have to try and jam over 11 gallons in it. In fact, over filling can damage the charcole emissions canister. You may simply have more fuel remaining in the bladder than you think. So don't fret it.
  11. Navigator
    22
    Fullerton, CA
    Yesterday, the last pip started flashing (I usually fill up with two pips left). I went to the fuel station, put the pump nozzle into the fill hole as with any other car, and pumped at full speed. The pump clicked off at 8.5 gallons. When I turned on the car, the fuel gauge slowly made its way all the way up to 10 pips full.:rockon:
    I have never, ever gotten more than 8.7 gallons into the car, and I don't expect to. Some fuel must remain in the tank, the secondary tank, fuel pump, and fuel lines all the way to the engine. If you empty these components, you'll enter the fuel station on battery power alone (not good). I have noticed that the bladder capacity varies a bit at every single fill up, but the guage reads full every time. It is easy to see that if I am averaging 334 miles per fill up, and typically put in 7.5 gallons, then my car is averaging 44-45 mpg, in the city during winter. My last car was a 4-cylinder that averaged 19 mpg under the same conditions. So, for sure, the Prius is getting better mileage on the streets. Oh, and by the way, my last car had a "normal" gas tank, and the fuel guage always screamed for more fuel when there was 2 gallons left in the tank. The Prius acts no different, in that department.
    Okay, so there was one thing I did do differently, yesterday, than I would with any other car. When I put the pump nozzle into the fill hole, I could feel resistance due to the rubber seal being bone dry. To correct this, I withdrew the pump nozzle and gently dabbed a few free drops of fuel onto the seal; friction was then gone. I rotated the nozzle a bit to seat the seal around the nozzle and then proceeded to fuel as usual. As I recall, some users on this forum have found that seating the rubber seal correctly improves the fueling experience. So far, I have found this to be true.
    Okay, just some thoughts on fueling the Pump & Pray Prius.
  12. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    I would say that you had about 3 gal left+ 8.5, = 11.9:D That's what the manual indicates when the light starts flashing anyhow.
  13. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    interesting. when i am five pips down, half a tank, i can usually get about 5 gallons in the tank when i'm filling up. however, interestingly enough, the other day, i was only THREE PIPS DOWN, i decided to fill up because i was on a long distance trip and got in 7 gallons!
    what gives? is this the bladder stretching? my car is an 08 with 15K miles.
  14. qbee42
    18,058
    3,079
    Northern Michigan
    Capacity varies by temperature, age, refueling pump, and perhaps the phase of the moon. Get used to it.
    Tom
  15. Navigator
    22
    Fullerton, CA
    Which is why I don't think we should be concerned with how much fuel is still left in the car when the last pip is flashing. Once you're down to a flashing pip, you really have no idea how much farther you can drive, at least until the ICE just stops running :eek: .
    The only concerns I have with the Prius fuel system is potential for non-stop clicking off of the pump nozzle during fillups and the surprise overfilling/barfing gas problem. Both of these problems seem to me to be due to a malfunctioning valve somewhere in the fuel system not allowing pressure to release as the bladder fills and expands. Other than those two issues, the Prius acts nearly no different than any other car.
  16. Navigator
    22
    Fullerton, CA
    I know we all like to start a long trip with a full tank, but with this car I wouldn't even bother filling until I'm down to 4 pips, tops. Consider, if your car took 7 gallons, that means you had, maybe, 4-ish gallons in the car before fueling. On the highway, my car easily gets 47 mpg with normal driving. But let's assume 45 mpg just to be safe. Assuming our cars behave identically, 45 mpg x 4 gallons gives you 180 miles to find a fuel station along the way. That gives you plenty of distance to find a station when your tank is down to, say, 2-3 pips.
    Another technique that I use is to reset my trip odometer at each fill up. My car has consistently gotten about 335 miles by the time I'm down to 2 pips. The car usually takes 7-8 gallons at that point. Using the trip odometer will give you a means for cross-referencing what the fuel gauge is showing.
  17. Genoz World
    797
    22
    La Canada
    yeah, i got it, but this variance is really a big number.,,,,,,,,i'll wait for another blue moon!
  18. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    The Bentley repair manual on page 2-10 indicates that capacity changes by 10% when the temp is 14F; that is about 1.2 gal at 14F.
  19. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    Jesus people, just sell your Prius and drive something else. It really isn't a big deal. Why oh why are people driving something that they can obviously sell (Prius market is much better than other cars). Either put up with the "problem" or drive another vehicle that "seems" to work "normal". Many seem NOT ready for new tech in their vehicles...
    Yes, I reallize other cars may have low emissions with no bladder...SO BUY IT! What's seems to be the hold up?
  20. jalynn2
    jalynn2 Junior Member
    Downingtown, PA
    I've read a few owners write "I know there are x gallons left when the gauge starts flashing". A word or warning: No you don't! Think of the flashing to mean "Get gas NOW!!!".
    My last car (Honda Odyssey) was good for at least 70-80 miles when the low fuel light came on. That's the mentality I had when starting to drive my Prius. I was on a long trip on the PA Turnpike where there's very limited access to fuel and the MFD said 56 average MPG. I went about 60 miles on 2 pips, but the gauge started flashing only 10 miles after dropping to 1 pip. No big deal, I thought, there's a gas station in 20 miles. 11 miles later, the dash lit up like a Christmas tree -- out of fuel.
    I never go on a limited access road any more with less than 3 pips.
    Forget that the owner's manual says 11.9 gallons. As others have said, you can only count on the capacity being whatever you put in on the last fillup. Also, my MFD reads a bit high: After 26000 miles, the total MFD-estimated MPG is 49.8, but my actual calculated mileage is 48.1.
    You've been warned.
