No Gain In MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by Walker1, Aug 24, 2008.
  1. patsparks
    10,664
    567
    Adelaide South Australia
    The key to better fuel economy is your right foot and constant vigilance. Want proof? Read the economy threads and try it yourself.
    Lowering the oil level works if it is too high and costs nothing but injector cleaner? I never saw anyone recommend that in a car with only 30 to 40,000 miles on it to improve economy. If your car had 100,000 miles on it and you used poor quality fuels I'd say injector cleaner MAY help.
  2. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Walker1,
    A couple of things to keep in mind:
    1. There is a break-in period for the tires themselves as has been mentioned in many threads. I've seen different explanations for it, and don't doubt that the observed effect is real. For me on other vehicles, new tires have always been stickier on various surfaces. Old tires that have been on the car for a few years just don't stick as well for me even though they are often the same exact model (not OEM though.) I don't doubt that they have lower rolling resistance as they age. The rubber compound tends to harden as tires age and that makes them less grippy in my experience. (Others' experiences may vary.)
    2. Since manufacturers don't report rolling resistance and there isn't a specific test and rating to put on the sidewall, accurate information is difficult to find.
    3. Injector cleaner would only make sense if you had seen a gradual decline absent anything else. I've never had injector cleaner do anything noticeable to any vehicle I've owned and I've tried it several times.
  3. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I recommend changing gas stations if you have a major brand on your route that offers a discount when using their credit card. Because there are too many variables I can't prove that changing to Shell helps the Prius FE as the Intrigue's hasn't moved at all. However, after the 5% rebate there isn't cheaper gas (for me) anywhere.
  4. Walker1
    Walker1 Empire
    911
    FL
    I use a credit card with a 5% discount @ any station. Just one thing- Sam's Club is about 25 cents less than any of the brand name stations and I think I've seen the ethanol signs on some of them when I fill up the Harley, which requires 93 octane gas.
  5. Walker1
    Walker1 Empire
    911
    FL
    I did notice as the original tires got thinner the MPG was up to 54 MPG. Perhaps I made an error by putting on what I thought were the stock tires & now I'm stuck with them.
    The 2006 has become my 2nd car now & I'm not logging many miles on it @ this time. I think between April & now I've logged about 2,000 miles. The 2008 is the daily driver for the time being.
    One thing I notice about the '08 vs. the '06- The '06 has colder & better A/C than the '08. I brought the '08 to the dlr. & they said it is OK. I guess that is to be expected from each individual vehicle.
  6. Celtic Blue
    2,224
    139
    Midwest
    If it is 25 cents cheaper then it contains ethanol. You are fortunate to be getting the mileage you've been getting.
  7. richard schumacher
    7,676
    1,059
    United States
    Your experience sounds like mine. Aging of the traction or 12V batteries can also reduce fuel economy. Everything gets old and wears out.
  8. nooaah
    nooaah New Member
    380
    Philadelphia
    Wow, I can't put my AC above the level past LOW before I start chattering. And this is in 90 degree temperature, though I'm sure now as humid as what you have to deal with daily.
