No Garage, no PHV?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by coach81, Dec 31, 2010.
  1. coach81
    coach81 Active Member
    758
    116
    Louisiana
    Awesome Flan.. thanks bro!
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    electric vehicle supply equipment.
    which is commonly known as the "charger". this is incorrect. the charger is internal to the car. the EVSE supplies the power to the charger.
    so it can be similar to an extension cord like the 120 volt emergency charger that comes with the Leaf which has a standard 120 volt plug on one end and the J1772 connector on the other.
    there are also hard-wired 240 volt chargers also using the J1772 connector
  3. jared1216
    jared1216 New Member
    US
    You should be able to hard-wire a unit and as long as the unit is waterproof be in good shape.
  4. coach81
    758
    116
    Louisiana
    Wonder how much it was cost to set up a power supply outside the home for plugging in???
