No guides on the rearview camera?
Discussion in 'Gen 3 Prius Main Forum' started by d2mini, Apr 20, 2012.
  1. d2mini
    d2mini Active Member
    519
    106
    Houston
    Every car I've driven with a backup camera displays red, yellow and green guides, overlayed over the image on the screen. Can these be turned on??? I don't see any mention of this in the manual. If not, the camera only seems half functional to me. How do you know how close you are to obstacles? :confused:
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    You just look at the image and the edge of the bumper to see how close. I've never had the lines since I've only had cams on my 2006 and on Prius and I have never had an issue to be honest.
  3. d2mini
    519
    106
    Houston
    ok, i hope so. After having the guide lines it's kinda freaky not too.
    They usually curve as you turn the steering wheel too, so you know your exact path the car will take. It's nice to have.
  4. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    When I'm backing up, I don't rely on the camera except for initial check to look for kids/animals etc and then how close I am to a parking bumper etc.
    I am sure those lines are something one would get used to but for me, before I looked at a screen while backing up using curving lines for my 'path' I'd just (or rather I do) turn my head and physically look behind me using the camera for what I mentioned above.
  5. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Ditto. Not a good idea to rely too extensively on the camera when backing up.
  6. The Transporter
    Sunny Surrey BC
    There are two short horizontal lines close to the bumper close to the sides. You could line those uo with the lines on the pavement or other obstacles behind.
  7. zdenok
    zdenok Junior Member
    57
    Bratislava, Slovakia
    I have those guide lines displayed, if I can remember, it can be switched on/off through touch screen when you are in reverse.
    iPhone ?
    Zdenok
  8. Tideland Prius
    16,680
    For the US market, I thought those with the HDD-nav have the guide lines now?
  9. d2mini
    519
    106
    Houston
    I do not know! I was hoping it could be turned on.
    I have a Five with Advanced Tech so maybe? But i couldn't find mention of it in the manuals.
  10. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    If they are I have not noticed them or have not turned them on. I'll look next time and turn em' on if I do have them but I don't think I'd use them since I don't reverse looking at the cam except before beginning to move and right at the end to see just how close I am to something.
  11. RaZa
    RaZa Member
    480
    93
    I've never had a camera before, but so far in my first week of having the car the backup camera seems like more a novelty. Kind of a "Hey Cool" sort of thing, but I honestly have barley looked (or even want to) look at it. Doesn't feel right looking down at the console when I'm backing up. I'd rather physically be looking at where I'm going. I can see glancing at it to look for obstacles, but otherwise I can live without it completely...
  12. HaveNoCents
    HaveNoCents Conservative Tree Hugger
    299
    48
    Crystal Beach, Texas
    Agreed. It's a toy with little practical use. The sensors are so much better than the camera.
    I am here: http://tapatalk.com/map.php?32l3jx
  13. fattymoocow
    fattymoocow New Member
    96
    Richmond, VA
    Whenever I'm in reverse, the camera is a little deceiving because objects show up farther away than you really are to whatever you are backing up to. So I always have to double check by turning my head anyways because I'm always a little worried that I'm actually too close to something even though it doesn't look like it in the camera.
  14. fuzzy1
    10,707
    Have you seen the demos of entire kindergarten classes hidden behind an SUV in a pattern where it is physically impossible to see any of them from the driver seat, from any standard mirror or over the shoulder through the rear and side glass? The same problem exists, on a smaller scale, with the Prius and very many other passenger cars as well. The gradually worsening rearward visibility of the motor fleet over the past two decades has been accompanied by a sharp increase in child backover deaths. That is why Bush signed a law that will effectively force backup cams soon.
    The rearward space that I cannot see from inside this car is considerably larger than that of my previous cars. And now a young child that lives next to my back up path has entered the high mobility phase. Now he easily has the ability to run up and hide behind while I'm getting seated, after I've inspected the immediate rear path from outside. The lack of visibility has make me increasingly nervous.
    I acquired a backup camera only yesterday, so can't yet comment on how well it works. The expectation is that I'll still be looking back through the hatch while backing, but will check the camera first before releasing the brake. And the camera should let me inch closer to fixed objects to make better use of available parking space than my less-than-ideal depth perception allows otherwise.
  15. d2mini
    519
    106
    Houston
    Ya, because being able to SEE is of little use. :rolleyes:
    They both have their merits.
  16. hoddy4
    hoddy4 New Member
    118
    NC
    Unless you have the ATP package the camera on the v (Level 3) will let you see whether something is behind you but probably will not be useful for spatial relationships or "inching" closer to fixed objects. The ATP provides a grid which may make it more useful.
  17. HaveNoCents
    299
    48
    Let's examine.
    1. You have to walk to get into your car. Use your eyes to look around before you get in. Driving 101
    2. You have two side mirrors and one rearview mirrorr. Do you really need 4 areas to divert your eyes?
    Hearing a sound is much better. I've had both systems in my car. The camera is a toy. The longer you own the car the less you will use it.
    Let's face it. If you are an observant person you will not need a camera, and if you're not observant a camera won't help anyway.
  18. d2mini
    519
    106
    Houston
    Yeesh, get over yourself.
    It's just another tool that comes in useful.
    Never had one before and don't need. Glad to have it now? Yup. Would guidelines make it even more useful? Yup.
  19. gsodonis
    gsodonis Recent Hybrid Convert
    47
    Loudon, TN
    The best rearview camera I ever had the priveledge of using was on a Hyundai Genesis rental car. I got a free upgrade to the luxury class in Orlando once and my choices were the Genesis, a Lincoln Towncar or a Hummer H3. The Genesis was the hands down winner and by the time we had to turn it in, we struggled to give up the keys.
    I'm a pretty old-school conventional sports guy type that hates automatic trannys and scoffs at gadgets, but the crash avoidance cruise control and the backup camera grew on me and I now see both of those technologies in a new light. Before talking my aged father out of his car keys at 85 yrs of age, he had his share of parking lot dings and fender benders that this type of tecno wizardry could have greatly reduced if not prevented outright.
    Of particular note was the combination of the rear view camera (with distance references and lines) and the proximity sensors in the bumpers. The lines establised a direct visual representation of the car's path - you caould tell what the car would hit (and/or miss) simply based off of the sight picture on the screen.
    I agree with the other posters that in the Prius' application, the back up screen shot is more for making sure that nothing is directly behind the car than it is a substitue for the normal method of looking around. However, I do wish we could upgrade the camera just to get reference lines as I do feel they help establish a clear path for the Prius rather than just what might be directly behind. Another tool in the drivers' toolbox.
  20. HaveNoCents
    299
    48
    Ok. I'm officially over myself. It still doesn't change the fact that the backup camera is a useless toy. Proximity sensors are far superior from a collision avoidance standpoint. If you have proximity sensors you don't need a backup camera, but you can't say the opposite is true.
