No Heat After Multiple Tries? Gen2 07
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mryankovic, Dec 27, 2024.
  1. ChapmanF
    19,059
    In my experience, the 700 to 800 watts of electrical PTC heat before the engine warms up is humanly imperceptible. The only way I can tell if it is on or off is the difference in how fast a foggy windshield clears. It takes more like the 5300 watts worth of hot coolant you get from the engine to make the vent air feel actually warm.
    (* I got the 5300 figure from gen 3, but assume it's the same ballpark for gen 2.)
  2. Mryankovic
    Mryankovic New Member
    WV
    The hose coming from the heater pump to the heater core which is the right side Inlet, that hose is hot the other one (left side heater core outlet) so something is stopping fluid from moving through that heater cord seems like I have no clue what though because I pulled the left side hose off and flushed it all the way down to where I disconnected the top hose from the coolant control valve so the entire heater core, electric heater pump and hose running all the way down to the control valve was flushed. I don't really care if this car Heats perfectly but as long as it has some heat, I wonder if it's possible to just entirely bypass this coolant control valve so I can only have heat when the car is running the engine. That would be a 100% acceptable solution for me if it would work.
  3. ChapmanF
    19,059
    That's not the only way of reading those observations.
    The heater core is a heat exchanger: the liquid gets pumped in warmer and leaves cooler, while the air gets blown in cooler and leaves warmer. The gozinta hose feeling warmer than the gozouta hose is pretty much what you should expect.
    That the gozinta hose feels hot is a pretty good sign the flow isn't completely blocked. If the flow were blocked, there would not be hot liquid flowing in that hose to make it feel hot.
    Now, whether the flow is full or sorta reduced, that could be a question.
    How much cooler the gozouta should be compared to the gozinta depends on a lot. A high cabin fan speed will take more heat out of the liquid than a low fan speed. Colder intake air will take more heat out of the liquid than warmer air. Slower-flowing liquid will come out having lost more heat than faster-flowing liquid.
    So there are a lot of questions you can ask or answer about the job that heat exchanger is doing, but good answers kinda call for good measurements of the gozinta and gozouta temperatures, and the fan airflow, and air intake and discharge temperatures. And the next challenge is the Toyota docs don't really tell you much about how to do that.
    I did just now look in the 2004 New Car Features manual and they did give the 5300 watt figure for the heat exchanger capacity for that generation. That presumably applies when the coolant is at full operating temperature, thermostat open, and the fan blowing the maximum airflow. If you knew the design flow rate of the liquid through the core, you could work back from the 5300 watts and get the temperature drop from gozinta to gozouta. If you knew the design airflow at max fan, you could likewise work out the expected air temp rise at 5300 watts. You could compare those figures to the temp drop / temp rise measurements you have IRL and get a good idea what's going on.
    Trouble is, the manual doesn't give those flow rates. It might not be hard to measure the airflow using the tools home HVAC techs use. The liquid flow rate you could get by inserting a flow sensor inline with the core—assuming you had a known working-right Prius to do that in, and not one where you already wonder if the flow rate is right. :(
  4. Mryankovic
    WV
    I did yet another flush both directions very thorough this time no luck. I still am getting the p1121 code and I'm going to see if I can return my OEM part for replacement because the only thing I have left to think now is that the heat I am feeling on the top hose of that coolant control valve is just being transferred through the material and actually mean it's flowing. If I could just put an elbow fitting in and bypass that three-way valve I would be overjoyed
  5. pasadena_commut
    pasadena_commut Senior Member
    3,072
    956
    Southern California
    You could do that but then it will throw codes because that would also disable the thermos mechanism.
  6. pasadena_commut
    3,072
    956
    Southern California
    Wait, since when do you get P1121? I don't see that in this thread except for your last post.
    Inspect the connectors on the plug to the valve for corrosion. A good valve won't work if it cannot talk properly with the rest of the car. If you have Techstream use it to test the coolant control valve.
  7. Mryankovic
    WV
    Yeah the code only appeared about 2 or 3 days ago during this issue but it had been ongoing for about 2 weeks without a code and all hoses going in and out of that coolant control valve were clearly hot since this issue started. I guess I'm going to double-check that and see what I can look at with the wires without tearing anything apart again, and then my plan is if the valve is broken and hard to move mechanically I'm just going to spin it to the correct position so that heat flows through the top, seems to me it already is but I don't have anything else to go off of.
    Other than connecting the pump while it is disconnected from the car to a 12 volt battery are there any other tests I should run on it? Thanks again to everyone that replied.
  8. Mryankovic
    WV
    Solved! No clue why the code was not being thrown immediately for the coolant control valve but I pulled it off and did a bunch of tests on it and could find no Faults with it. I put it back on to see what would happen and tried bleeding the system again and voila! It worked, the code is still there but it is obviously functioning correctly as I have heat both when the engine is on and off, this car is getting up there in age to the point where if this happens again I am just going to put a t fitting in place of that coolant control valve and accept whatever other consequences occur just to get heat while the engine is running. I cannot tell everyone how thankful I am for them taking the time to give me the advice to do this because I only narrowed it down after doing a thorough flush of the whole system and determining there are no blockages.
    Brian1954 likes this.
  9. pasadena_commut
    3,072
    956
    Southern California
    Clear it and see if it comes back.
    Happy the heat is working now. Crossing fingers it stays that way.
    Mryankovic likes this.
