1. rmg
    rmg Junior Member
    Romania
    Hello, I have a Prius from 2011 and the same problem: I checked and removed the air from the installation, I left the car in maintenance mode for one hour on the maximum heat, I checked the hoses that come inside and they are hot, I checked on Torque and the temperature stays at 86 degrees,the antifreeze is on level, the fan on the radiator starts and yet it does not add heat. Sometimes, when it wants, it adds some warmth but nothing spectacular. It would help me any idea about what checks to do in the area of the dashboard, because that is definitely the problem. the heat reaches the inside but is not distributed.
  2. 310 Prius Owner
    310 Prius Owner Junior Member
    IL
    I have 2010 Prius and I can't get any heat in the cabin. I checked my coolant lines going to and from the heater core and they are getting nice and warm. I watched the servo mix motor and it will rotate when I go from hot to cold. We have about 5 of these Gen 3 Prius so I can borrow parts from one to try on this one. I tried the climate control cluster and still get the same results, no heat.
    Does anyone have any help for me?
  3. JC91006
    16,936
    8,647
    this thread started in 2014, it's best you start a new one of your own, it'll probably get more response that can help you
  4. 310 Prius Owner
    IL
    Thank you! I did that.
  5. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    Make sure your mixer servo is going all the way to hot. Mine had been sticking last summer, not going completely to cold/AC, but seems to have resolved, knock on wood. I did find a stored history code for a stuck servo motor in Techstream, but that code may not appear on all code readers.
    Try setting the temperature to low (in Auto mode), then hold the temp ^ until you get to hi. Do this a few times with the engine nice and warm-maybe it'll help.
