1. Jl2005prius
    Jl2005prius New Member
    Ny
    Hi- 2005 with no heat. I’ve verified mechanical thermostat, so now working on heater core circuit, specifically the electric aux. pump. I’m not clear which fuse controls that pump, however none are blown. Can anyone tell me which fuse? I’d like to jumper the pump to see if it’s running.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,110
    2,011
    NJ-USA
    Power for the A/C (heater) water pump goes through a relay fed by the 10A Gauge fuse. If the speedometer works, then that fuse is ok. The hybrid control ecu turns the relay on or off.
    AFAIK, that pump is only used to circulate coolant when heat is requested and the (hot) engine is turned off. It is difficult to check directly as that pump is behind the inverter.
    A more likely item to check for a no heat concern would be the temperature blend door actuator. You can sort of see it from under the driver's foot area. Above the gas pedal toward the center are two black plastic boxes on the HVAC housing with linkage bits on them. The lower one is for temperature control.
    Have the car in ready mode and watch the actuator- see if things move while someone else has the heater on and commands full cold to full hot.
  3. mr_guy_mann
    4,110
    2,011
    NJ-USA
    Here is the pump right near the ABS unit (driver's side of engine compartment) with the inverter removed. DSC_8363.JPG
    #3 mr_guy_mann, Mar 21, 2023
  4. Jl2005prius
    Ny
    Thank you very much. It seems there is no or very low flow of hot coolant into the pump, as the hose remains cool, even though the input hose to 3-way valve is hot. I’m going to pull the wiper assembly tray and verify heater core is not plugged, as well as the pump and 3-way valve. In my case the problem seems to be coolant flow related. I’m not getting hot coolant through the core
  5. mr_guy_mann
    4,110
    2,011
    NJ-USA
    Might want to check hose routing at the 3-way coolant control valve. I have read that having a couple hoses swapped will cause heater flow problems. Screenshot_20230323-084851.jpeg
  6. Jl2005prius
    Ny
    Yes, thanks…. It has worked well for many years, and the valve was replaced a couple years ago…simply due to a code which occasionally would come up. heat just recently has become an issue. I suspect a blockage at electric pump or in the core.
  7. Jl2005prius
    Ny
    I’m preparing to flush the heating system and storage container. I suspect there may be problems with heater pump. Can anyone tell me where the relay is for the HEATER pump? I’ve found the canister pump relay… is the heater pump relay in the same relay box on the wiper tray?
    Thanx
  8. ChapmanF
    18,961
  9. Jl2005prius
    Ny
    Well, yes… I found the wiring diagram. But I’m not able to figure out where the actual relay is physically located. It’s clearly listed in the wiring diagram as AC WP relay. But I apparently am not smart enough to tell from the diagram where to actually find it. I will go look at all the relays in various locations to see if I can find one labeled AC W/P
  10. furok23
    furok23 Junior Member
    22
    Bay Area, CA
    SE
    I'm chasing a similar problem. Just replaced my 3way coolant valve and didn't fix anything.
    Given that you're chasing down internal systems, I assume you've verified that you have good airflow from your HVAC system?
  11. Jl2005prius
    Ny
    Yes, I’m quite convinced it is a coolant flow restriction. The hose going from 3-way to heater pump stays cool to Luke warm, even when heat is on max. Airflow is great. I replaced the 3-way last year.. it was occasionally throwing 1121 code. My plan is to flush everything in the engine/heater system and possibly replace the pump if it is bad or plugged.
  12. ChapmanF
    18,961
    One of the earlier sections of the wiring diagram manual is Location and Routing, and one (maybe a subsection of that) is relay locations.
    The gen 2 has a couple of "integration relay" units, several relays combined in one long skinny block. (One of them also has four fuses, the other just looks like four blank fuse slots.) I don't remember offhand if the AC WP relay is in one of those, but if it is, it will be shown that way in one of the "inner circuit" drawings.
  13. furok23
    22
    Bay Area, CA
    SE
    That's the topmost hose of the valve, right?
  14. Jl2005prius
    Ny
    I believe so…. It is the one which is routed around inverter and back toward firewall.
  15. Jl2005prius
    Ny
    Ok- I understand….. yes, that’s how the relay is listed, on the inner circuit diagram. I think I can locate it now
    Thanx
  16. Jl2005prius
    Ny
    I’m preparing to tear into this heating issue and have some information to share. I found a good used heater pump, to use in the event mine is bad. It seems this is not a positive displacement type pump, so coolant passes through easily, even when pump is not turning. I did not realize this; for some reason I thought the pump runs whenever heat is turned on. So even if the pump dies, this should not prevent coolant from passing. This must mean there’s an actual block somewhere….or the valve is stuck. I’m going to start the investigation by pulling off the hose on valve which feeds the pump and blow thru it with radiator cap off to see if there’s a blockage….. just thought I’d share in the event anyone else is facing this mystery
  17. ChapmanF
    18,961
    Yes, that was a change they covered in the 2004 New Car Features manual. The same pump in Gen 1 had required a bypass valve around it that would shift positions when the pump started or stopped. By making the pump easier to flow through, they eliminated the need for that valve in Gen 2.
    (Then, of course, they added the thermos in Gen 2, with a different valve and actuator and pump needed for that.)
  18. Jl2005prius
    Ny
    Thanks everyone for your input- here’s an update: I pulled the hose from coolant control valve which goes to heater core.. I’m able to easily push air through with radiator cap off… so nothing blocked thru core. The problem is the 3-way valve, which I replaced last year due to a code … but no issue with heat. Now I have no heat and the valve is stuck. Stupid me… bought non-Toyota Dorman brand and it apparently only lasted a year. I bench tested the valve and it sounds bad/ sticks occasionally. This time I have Toyota OEM valve and will be flushing the entire ICE coolant system and doing the air purge dance, etc. hopefully this will get me back in shape..
  19. Jl2005prius
    Ny
    I now have heat
  20. ChapmanF
    18,961
