NO HEAT
Discussion in 'Gen 3 Prius Main Forum' started by rondefly, Oct 27, 2023.
  1. rondefly
    rondefly Junior Member
    South Lake Tahoe, CA
    How to burp a 2015 Prius , where is the vent plug? air is trapped somewhere in the system. Ron
  2. ChapmanF
    19,017
    Are you sure trapped air is the problem, or is the problem "no heat", with trapped air as an explanation you've settled on?
  3. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
    Did you suddenly have no heat? Or did you change the engine coolant and
    now you have no heat?
    If you drained it, did you fill it quickly? Or VERY slowly? Pooring slowly and pausing
    for 10-15 senconds to allow the coolant to settle and push out the air.
