No Heat
Discussion in 'Gen 2 Prius Main Forum' started by qmanqman, Oct 20, 2025.
  1. qmanqman
    qmanqman Active Member
    444
    153
    CO
    Ya I checked it this morning and had to add a few oz's. I'll keep checking after every drive.
    BiomedO1 likes this.
  2. pasadena_commut
    pasadena_commut Senior Member
    3,034
    942
    Southern California
    That's a lot. I would suspect a leak. Have the radiator cap tested. One way they fail is that they open up at too low a pressure, but high enough that the coolant just evaporates when it blows out. Result: mysteriously disappearing coolant.
  3. qmanqman
    444
    153
    CO
    Ya I'll figure it out. Usually a leak presents itself with the smell of coolant. I have never smelled coolant which would mean that it is either so small you won't smell it or the leak is internal. Either way I'm on it.
  4. pasadena_commut
    3,034
    942
    Southern California
    Our Accord had the "bad radiator cap" leak. There was no clue, coolant just disappeared with no sign of it anywhere. We looked everywhere, even inside the cylinders with the radiator pressurized, in case there was a head gasket problem. Didn't make any sense until the cap was tested and found to be defective. (Ordered a replacement from RockAuto, not OEM but a well known and usually reliable brand. Luckily still had the rental radiator tester when it came. The replacement cap wouldn't open, even at pressures far above its rating. Gave up and bought an OEM cap for several multiples of the nonOEM's cost at the closest dealer's parts department and all was good.)
  5. qmanqman
    444
    153
    CO
    Looks like the water pump is leaking.
    Does AISIN WPT111 sound like the right part?
  6. pasadena_commut
    3,034
    942
    Southern California
    That is listed as an option on the RockAuto site. I would buy it from there rather than Amazon or Ebay to avoid a counterfeit part.
  7. qmanqman
    444
    153
    CO
    You thin the AISIN store on Amazon might be selling counterfeits?
  8. ChapmanF
    18,996
    There was a white paper on counterfeiting that I encountered several years ago. I think I linked to it in at least one thread here.
    It mentioned a large online marketplace (without naming it) where a lot of different sellers might be offering the 'same' item description, and the marketplace would accept your order with a specific seller and then ship you the 'same' item from whichever seller's stock is warehoused nearest you.
    Although the paper didn't name the marketplace, I have known Amazon to do that, at least one time for sure. During the lockdown, I was shopping for a knife sharpener gizmo that was advertised by a bunch of different sellers, and I earnestly took my time reading all their about pages and reviews and finally chose one of them to order from, and the shipment I got identified one of the sellers I had decided not to order from.
    I have no idea whether they still do that, or not.
    I guess it's efficient and gets you the item quickly—as long as the 'same' item as described by different sellers really is the 'same' item.
    qmanqman likes this.
  9. pasadena_commut
    3,034
    942
    Southern California
    My understanding was slightly different, that Amazon put all "XYZ" parts in the "XYZ" bin in the warehouse, no matter which seller provided "XYZ". Where "XYZ" is supposed to fully identify the part, like a Toyota OEM part number. Person orders that part, Amazon takes it out of that one bin, and that's the one you get. Might be OEM, might be counterfeit. Allows a sort of parasitic relationship between the counterfeiters and the manufacturer, since some of the counterfeiter's orders will be filled with OEM parts. So at least some happy customers for the seller supplying counterfeit goods (OEM part for less than OEM cost). From the manufacturer's perspective it is all negative. Pretty much like how a cow views blood sucking insects.
  10. qmanqman
    444
    153
    CO
    New pump in and plenty heat and no more coolant loss.
    Almost forgot . . . topped it off with Walmart coolant.
    #30 qmanqman, Nov 3, 2025
    Brian1954 likes this.
  11. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You really should stick to Toyota Super Long Life (red) coolant in a Gen2 Prius.
    JeffD
  12. qmanqman
    444
    153
    CO
    Why?
  13. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It is a proven product with a long track record and is good for 50,000 miles. Other formulations need to be refreshed every 25,000 miles.
    JeffD
  14. qmanqman
    444
    153
    CO
