No homelink on a 2020 Prius Prime XLE?
Discussion in 'Prime Main Forum (2017-2022)' started by Shaunius, Aug 13, 2019.
Tags:
  1. Blauer Glimmer
    Blauer Glimmer Active Member
    448
    169
    NY (Southern Tier)
    Have never been able to make HomeLink work :( I think my garage door opener is just too old.
  2. CharlesH
    2,797
    1,163
    Roseville, CA
    I have a Chamberlain Liftmaster (aka Craftsman) opener which has rotating codes, and it works fine with the HomeLink. As I recall, there are two steps: one to tell the HomeLink what brand opener you are using (using a remote for that opener near the Homelink while pressing certain buttons on the Homelink), and the second to pair it with the opener to synchronize the codes.
  3. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    OK, that’s interesting... I haven’t had a chance to investigate that feature much yet, but it would seem like the garage door opener and it’s remote would have to run an exactly identical, synchronized algorithm for choosing codes each time. Meanwhile, Toyota’s Homelink rear-view mirror will always spit out exactly the same code every time you press the button.
  4. CharlesH
    2,797
    1,163
    Roseville, CA
    Apparently, the HomeLink in the car does the right thing with rotating codes, since I have had it work with two different Chamberlain openers that definitely use rotating codes. The opener can deal with several different remotes (independent code sequences), and deals with skipped codes, like if you hit the button on the HomeLink but you are out of range of the opener. The HomeLink is transmit-only, and has no way to know if the opener actually heard it.
  5. mr88cet
    2,313
    1,335
    Austin, TX
    OK. Hmmm... Do you know that it actually is for-sure rotating codes in that usage?
    iPad ? Pro
  6. Tideland Prius
    16,559
    Be aware if you have a newer garage door opener, you may require a Homelink compatibility bridge kit. (about $20-$25)
  7. CharlesH
    2,797
    1,163
    Roseville, CA
    You know, I actually don't know. The manual for my opener says that if the opener is operated with a non-rolling code transmitter, that the door will operate, but the rolling code functionality will be disabled. o_O
    mr88cet likes this.
  8. mr88cet
    2,313
    1,335
    Austin, TX
    Gotcha.
    From a security perspective, my take would be that the most important consideration is that no single, fixed code will open the door.
    If it requires a different code each time, and that code is effectively impossible to predict, then more likely than not, a thief is going to target your neighbor’s house instead (or at least a different door, be it on your house or your neighbor’s).
  9. Mendel Leisk
    41,466
    I couldn't fathom it. Our son had it sorted out in about 10 minutes. :oops:
  10. 2015BlizzardPriusFour
    2015BlizzardPriusFour Active Member
    171
    142
    Central Valley CA
    We did have the homelink, so it’s setup, but with 4 cars and only 2 remotes, I went with a garmin speak plus dash cam with Alexa and a cheap device made by Garadget hooked up to our older garage door opener. I can either choose to do geofencing (opens and closes based on distance) or by voice command.
    iPad ?
  11. bresna
    bresna Active Member
    193
    144
    Southern Maine
    Am I the only one who finds it odd that Toyota's XLE is no longer their top of the line? I remember when the Limited trim came out on certain models. They were limited, which meant what it was supposed to mean - only available for a certain number of cars. The package usually had custom features not found on other cars. Stuff like special body treatments, special off road package, special interiors, etc. Now, it's just become XXLE. :)
    On-line Dictionary
    lim·it·ed
    /ˈlimədəd/
    adjective
    1. restricted in size, amount, or extent; few, small, or short.
      "a limited number of places are available"
      synonyms: restricted, finite, bounded, little, narrow, tight, lean, slight, slender, in short supply, short;
    Nowhere in there does it say, "Fully loaded".
    Shaunius likes this.
  12. bisco
    51,950
    agreed. toyota still hasn't figured out model names that make sense, or maybe they don't want to
    Shaunius and Mendel Leisk like this.
  13. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    Ever since I have discovered these 'keychain' openers, the lack of homelink in our two Prius vehicles doesn't bother me as much.
  14. Cavi
    Cavi New Member
    Red Bluff Ca
    2022 Prius Prime
    what keychain opener?
  15. farmecologist
    1,958
    1,799
    Southern MN
  16. Gokhan
    Gokhan Senior Member
    6,217
    2,465
    Paramount CA
    You are also missing the crucial safety features on the XLE, such as the radars for the blind-spot monitor and rear cross-traffic alert.
    HomeLink on my Prius Prime Limited works wonderfully well, with both the new push-colored-button-program garage door opener and the old Multicode dip-switch gate opener.
    I also carry two different key-chain remotes I bought from Amazon in my pocket, one for the push-colored-button-program and one for the Multicode, which I use when I'm not in my car. It's a pain to reach them when you're sitting in your car, and HomeLink is by far more convenient than them.
    #36 Gokhan, Nov 2, 2021
    pghyndman likes this.
  17. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    I don't miss the homelink mirror. Had it on my 2016 Prius Four and the crossbar in the hatch window put a shadow exactly where headlights from cars behind me hit the light sensor so I had too many long drives blinded by the car behind me. The Prime has a little dip which may help with that but I prefer being able to flip the mirror myself. The greenish tint on the autodimming mirror was also pretty weak.
    The harder plastic sun viser had my clip on door opener sliding a bit but some stick on foam helps
  18. PixelRogue
    488
    86
    US
    Gokan - not expecting you to see this post. I just picked up a Prime XLE (and yes, feels weird it is not top of the line trim after all the years of XLE branding.) Did you use a HomeLink mirror from a Gen3? I have one from Gen3 and would like to install in the Gen4.
    Gokhan likes this.
  19. Gokhan
    6,217
    2,465
    Paramount CA
    No, I have built-in Homelink in my Gen 4 Prius Prime Limited. I am not sure if you can replace the cells in the Toyota accessory Homelink.
  20. Kevin Kellogg
    Kevin Kellogg New Member
    Prescott, AZ
    2020 Prius Prime
    On my 2020 XLE Prime I used Velcro and stuck the remote below and behind the shifter and out of sight. Very easy to reach below and engage the garage door opener.
    Gokhan likes this.
