No Idea what is wrong
Discussion in 'Gen 2 Prius Technical Discussion' started by Uniquename, Apr 28, 2014.
  1. Uniquename
    Uniquename New Member
    Not sure if I have the right stop to post in,
    I have a 05 prius, not sure if it is 1st, 2nd, or 3rd generation.
    I overfilled the oil level, on accident and then something happened and then got distracted by something else.
    So I leave for work and in the first 5 miles of my 60 mile commute to work & the red triangle comes on but car keeps running normally.
    I make it to work, After work I start the car and it is making a whirling sound I have never heard before,
    It will not accellerate. I makes it to about 19 - 27 miles an hour then shuts down.
    I put a code reader on it and only two codes come up
    POA92 & POA7A
    Does any body know what these mean?
    Thanks in advance
    49,443
    probably not the oil, how much did you overfill by?
  3. Uniquename
    1 quart- I since then drained the quart off, and cleaned the throttle body but still making the same sounds.
    49,443
    a whirling sound might be your inverter coolant, but we need someone with the codes.
  5. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Did you do anything with the transmission fluid (ATF) at the same time as you did the engine oil?
  6. Uniquename
    Nope
  7. Uniquename
    I replace the inverter coolant pump a year ago - it still appears to be working- fluid is moving in the reservoir.
  8. bisco
    49,443
    there is a thread here including a POA7A and it ws a blown tranny. don't know how specific it is tho, the dealer replaced the inverter first.
  9. bisco
    49,443
    how many miles on her?
  10. Uniquename
  11. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Where are you (and your Gen2 Prius) located? There are several good independent Prius repair garages scattered about the country (Fl, CA, NC, IN, ...)
    DoctorD
  12. bisco
    49,443
    wow.:eek:
  13. Uniquename
    South east Louisiana
  14. jdenenberg
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
  15. Uniquename
    Checking the Blue book value of the prius in my area, the value is rather low.
    So I will have to weight the cost of fixing and the value of the vehicle.
  16. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
  17. vskid3
    vskid3 Active Member
    773
    228
    Also factor in that the rest of the car has gone 278k miles and could possibly end up needing a lot of fixing in the next couple years.
  18. Patrick Wong
    18,200
    6,472
    P0A92 means either the transaxle or the inverter has failed.
    P0A7A means that the hybrid vehicle ECU, transaxle, or inverter have failed.
    You might want to get your local Toyota dealer to obtain the DTC and info codes to more precisely pin down what is wrong with your car. Good luck.
    cwerdna and dorunron like this.
  19. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    One thing is for certain. The OP got a good run out of that Prius. Well past Toyota's expected "lifetime". When you consider the location which is more than likely hot and probably humid, plus possible salty air also those factors speak volumes as to the quality of the Gen II Prius.
    Ron (dorunron)
    olerox likes this.
  20. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    230k is AWESOME
