No, It’s Real: EV Range Down
Discussion in 'Prime Technical Discussion' started by mr88cet, Jul 12, 2018.
  1. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    Scheduled in the middle of the night. I only can charge at home and once a day, so that may be the difference..
    mr88cet likes this.
  2. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Again, good thoughts; thanks!
    Excellent! Thanks again.
    #22 mr88cet, Jul 13, 2018
  3. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    I'm confused. Are you making your whole trip in EV mode? Or is the ICE running and providing about 1.2 KWh of energy to make up the difference? If you're entirely in EV, the charge energy should be equal to the energy used, not the battery capacity.
    52,814
    the battery is over 8 kw.
  5. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    Battery degradation of almost 17% is pretty unacceptable IMO in 2 years. If you can verify this and bring this up to Toyota warranty, I’d be very interested in what they say. I don’t want to have a leaf situation in my hands.
    mr88cet likes this.
  6. mr88cet
    2,313
    1,335
    Austin, TX
    I am driving my commute entirely on EV.
    Those numbers (originally 6KWh down to 5KWh) are how much ChargePoint reports for charging it to full from “empty,” meaning the EV-HV threshold.
    8.8KWh, although there are 10-15% top and bottom margins, plus of course ... something like 800Wh for Hybrid-mode operation.
    Thanks, that’s my impression as well. Plus it’s only about a year and a quarter.
    I suspect that the batteries themselves are intact, but the computer is blocking off some of the top end to increase the top charging margin, to improve long-term battery life. That, probably in response to higher (outdoor) temperatures and the fact that I’ve been leaving it mostly charged overnight.
    I’m testing that Theory now by going back to charging mostly right before hopping into the car.
    #26 mr88cet, Jul 13, 2018
    jaqueh likes this.
  7. bisco
    52,814
    15% on my pip, and toyota said that is normal. plus, they said i'm still getting better than the monroney, so pound sand.:p
    jaqueh and mr88cet like this.
  8. mr88cet
    2,313
    1,335
    Austin, TX
    Good info. 15% degradation after how long?
  9. bisco
    52,814
    a year or two, stabilized after that. i only have 39,000 ev miles, evenly spread out.
    but it didn't happen overnight, it is a slow process.
    mr88cet likes this.
  10. mr88cet
    2,313
    1,335
    Austin, TX
    Interesting...
    Well FWIW, it’s currently sitting at about the official 22-25 mile range promised...
    Did it degrade in 2-3 mile steps like I saw?
    That is, 4ish weeks ago it dropped instantly 31 to 27 (one charge got 31 miles and the next was 27), then it stayed there at 27ish, until about a week ago when it instantly dropped to ~25 (again, one chafe was 27ish, and the next was ~25, and it’s been sticking there.
    Or was it a more or less continuous, gradual degrade?
    #30 mr88cet, Jul 13, 2018
  11. bisco
    52,814
    wow, that just seems wrong. especially with all the prime owners here and no one else reporting anything.
    bob wilson would be all over this.
  12. mr88cet
    2,313
    1,335
    Austin, TX
    “That” meaning it’s range dropping in distinct steps?
  13. Mendel Leisk
    42,314
    Distinct steps sounds like the programming's involved. The battery's condition decayed beyond some threshold defined in the programming, and the programming changed how much it'll charge, something like that? Out of my depth btw.
  14. bisco
    52,814
    yes. does sound like programming. don't have it on the pip. i would say heat related, i don't really understand why it would be programmed to not fully charge depending on how you are charging.
  15. Mendel Leisk
    42,314
    Well "full" charge is 80%, something like that? Who knows.
  16. bisco
    52,814
    it's not that, it's how many kwh it is taking from 'empty' to 'full' now, compared to before.
    Mendel Leisk and mr88cet like this.
  17. mr88cet
    2,313
    1,335
    Austin, TX
    Indeed, about 6KWh originally, now about 5KWh.
    I suspect there are, not surprisingly, several factors involved here:
    1. Warmer temperatures so the computer doesn’t want to push the batteries too much.
    2. I’ve recently been not going directly home from work, but instead going to the local mall to charge up on the Austin Energy $1 per week “all-you-can-charge buffet” rather than doing a scheduled charge at home right before I leave the following day. Therefore, it’s spending more time (all night) closer to the to limit of the battery, so the computer has expanded the top charging margin.
    3. The Guestimatron has changed its estimation parameters, in response to all of this and greater air-conditioner usage. This makes assessing how much the battery capacity has changed ... a little cloudy.
    4. Of course, how many miles I’ve gotten in he past per charge has varied some, historically, again making it a little cloudy.
    However, the drop in amount charged, from 6KWh per charge down to 5, is a clear, objective, measurable difference — nothing “cloudy” there.
  18. bisco
    52,814
    number two just doesn't make sense to me. (not that that means anything:cool:)
    spending a lot of time fully charged may be bad for the battery, but i don't see why the computer would expand or contract the charging percent due to that.
  19. mr88cet
    2,313
    1,335
    Austin, TX
    OK, two new data points:
    First data point: Yesterday evening, I drove straight home from work (i.e., instead of charging at the local mall on the way home, as I have the last 2-3 months). Historically, when I have driven directly home, upon arriving at home, I would have about 11 miles predicted EV range. This time I had about 4 miles. In both cases, this is after charging to “full” (which ChargePoint says is about 1KWh less now) at work.
    Second data point: This morning, I drove to my rowing club and back on a single charge, after charging to “full” at home. Historically, when I did drive directly home, I would make it back home with about 4 miles of predicted EV range left. This time, I had -0.4 miles (the ICE kicked in 0.4 miles before arriving home). Both of these data points are without using the air-conditioner.
    #39 mr88cet, Jul 14, 2018
  20. mr88cet
    2,313
    1,335
    Austin, TX
    So, the concept would be that, if I insist upon spending more time at the top limit of the battery, it will lower that top limit, in order to reduce wear upon the battery.
