No, It’s Real: EV Range Down
Discussion in 'Prime Technical Discussion' started by mr88cet, Jul 12, 2018.
  1. bisco
    52,891
    would be interesting to find out, maybe not a bad idea.
    mr88cet likes this.
  2. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    I’ll report back whether and when the range goes back up.
  3. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    Has your range changed at all?
  4. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    Are there any difference in your daily average kwh/mile records in the past few weeks?
  5. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    Miles per kWh, I meant.
  6. mr88cet
    2,313
    1,335
    Austin, TX
    Miles per KWh doesn’t seemed to have changed, only the number of KWh charged each time has reduced.
  7. bwilson4web
    16,552
    Preliminary data does not look good:
    The traction battery appears to have lost (6.15-5.90) / 6.15 = 4%. This is bad. However, I noticed the traction battery was only accepting ~14.8A instead of the 16A when the battery was new. . . .
    Expand your browser window to see the two, EV JuiceNet, screen captures:
    [​IMG] [​IMG]
    • First one is at Propst, Pratt Ave., on two legs of three phase, 210 VAC.
    • Second one is at home on both phases of 240 VAC.
    #47 bwilson4web, Aug 7, 2018
    mr88cet likes this.
  8. nw_mr2
    nw_mr2 Junior Member
    Portland
    3 days worth of data? 4% is well within the noise considering temperature, AC use, etc. What am I missing...
  9. bwilson4web
    16,552
    You count funny.
    padroo likes this.
  10. ETC(SS)
    7,575
    Looking at the graph above I guess I count funny too.....
  11. bwilson4web
    16,552
    Source: George Orwell - 1984 - Part 3, Chapter 2
    O'Brien held up his left hand, its back towards Winston, with the thumb hidden and the four fingers extended.
    'How many fingers am I holding up, Winston?'
    'Four.'
    'And if the party says that it is not four but five -- then how many?'
    'Four.'
    The word ended in a gasp of pain. The needle of the dial had shot up to fifty-five. The sweat had sprung out all over Winston's body. The air tore into his lungs and issued again in deep groans which even by clenching his teeth he could not stop. O'Brien watched him, the four fingers still extended. He drew back the lever. This time the pain was only slightly eased.
    'How many fingers, Winston?'
    'Five! Five! Five!'
    'No, Winston, that is no use. You are lying. You still think there are four. How many fingers, please?'
    'Four! five! Four! Anything you like. Only stop it, stop the pain!'
    Of course if you count from 0, there are 3:
    benagi likes this.
  12. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    I see 72 or 73 hours worth of data, depending on whether I start at 0 or 1 :)
  13. ETC(SS)
    7,575
  14. nw_mr2
    Portland
    Anyway...
  15. bisco
    52,891
    the first year or two, i lost about 15% of pip range. isn't that fairly standard for lithium?
    but i do think the software will limit battery capacity to some degree in intense heat.
    i have no bwilson data to back up my claims.:oops:
  16. padroo
    padroo Senior Member
    2,763
    2,253
    I don't understand how they keep all those individual cell in balance. With my RC battery packs with just three cells
    it is important to do a balance charge every now and then. How do they keep all these cells in balance because the battery is no better than it's weakest cell.
  17. bisco
    52,891
    there is a bms (battery management system), it does a pretty good job.
    padroo likes this.
  18. padroo
    2,763
    2,253
    I know but thee isn't much information about it. As time goes on the Li-ion batteries will fail with age and cycles and this will look like the Gen 2 forum. You guys with the PIP will be up to bat some day.
  19. bisco
    52,891
    absolutely. toyota doesn't give much away, but i think a few really bright ee's have done some exploring over the years.
    isn't that the nature of batteries, or is there a better way?
  20. bwilson4web
    16,552
    After reviewing the literature, the bulk of the papers are aimed at microscopic effects such as compounds blocking cathode access and lithium plating. These are separated from independent variables I can control. Stepping back, there are three independent variables:
    • temperature - using time of day scheduling
    • rate - using the amp setting
    • partial discharge - raise the lower SOC by enabling HV before running battery out
    The temperature test used the coolest part of the day, just before sun rise, and we are seeing a rapid and significant loss of capacity.
    The next test will limit the charge current to half of the 14.7 A measured. So I'll configure the JuiceBox to limit current to 7 A and enable charging two hours earlier, 2:00 AM instead of 4:00 AM.
    Partial discharge is harder since measuring the effect requires a full discharge. What I'll probably do is set a target of 10% to switch from EV to HV mode. Do this for a week and retest to full discharge. This has the effect of further limiting cathode depletion during discharge.
    #60 bwilson4web, Aug 7, 2018
    benagi and bisco like this.
