No, It’s Real: EV Range Down
Discussion in 'Prime Technical Discussion' started by mr88cet, Jul 12, 2018.
  1. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    You can roughly estimate it by seeing estimated range (climate off)/ estimated miles/kWh when you’re fully charge. All the info you need for that is in the middle page of the screen to right of the speedo.
    52,816
    garage won't help much. the estimate is based on past driving, and actual ev range will be determined by driving environment, not charging environment.
    mr88cet and jaqueh like this.
  3. jaqueh
    341
    199
    San Francisco
    I have noticed though that my car will say it’ll take 2hr and 20 minutes to charge, but when I come back 1 hour and 30 minutes later it’ll say 10 minutes left. Temperatures are pretty temperate in California too, so I do think charging times offer a clue about capacity.
    52,816
    absolutely.
    funny though, even though i have lost roughly 15% range, my pip still takes 90 minutes to charge
    jaqueh likes this.
  5. Blauer Glimmer
    Blauer Glimmer Active Member
    448
    169
    NY (Southern Tier)
    So, I’ve dropped from a monthly average of 4.7 miles per kw to 4.0. The cold weather would account for that. However, it doesn’t account for the entire 8 mile per charge drop in range.
    jaqueh and mr88cet like this.
  6. jaqueh
    341
    199
    San Francisco
    Yeah, .7*6 is about 4 miles so there's another 4 miles missing somewhere.
  7. bisco
    52,816
    miles per kw are affected by driving in the cold. with the same battery power, you would lose to air and road friction on a clear day, more in weather, and the battery/inverter/motors are less efficient
  8. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Thankfully, I have not noticed much change in miles/KWh; just a smaller number of KWh charged to “full.” Then again, this is Austin TX, so it doesn’t get particularly cold here, and I use climate control pretty moderately.
    That agrees with my experience as well.
    #128 mr88cet, Dec 8, 2018
  9. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    If somebody is losing miles per kWh, that's not a loss of battery capacity. You could lose 90% of your battery capacity and still you would get the same distance on that last 0.6 kWh as you would on 0.6 kWh when the battery was new. The telltale sign of battery capacity loss is the miles per kWh remaining relatively constant and the EV miles decreasing.
  10. Blauer Glimmer
    448
    169
    NY (Southern Tier)
    Both appear to be happening in my case. The cold accounts for the loss of miles per kWh, but there is more range loss than can be attributable to that alone. The decreased time to charge (approximately 1 hour less from 0 to “full”) is what concerns me most.
    The manual says extreme cold or heat can cause the battery to accept less of a charge but still read full. However, the cold here has not yet reached what I would consider extreme, and I always charge in the garage. The manual also says if this happens without extreme cold or heat to take it to the dealer. Since my dealer has zero knowledge about the Prime, I came here first for advice.
    #130 Blauer Glimmer, Dec 9, 2018
  11. bisco
    52,816
    and you are getting it.
    trust me, i've been doing this for 6 1/2 years. range starts drooping in the fall when temps start drooping below 70f.
    right now, i'm down 30% from my summer high, and it has done this from the first winter i had it.
    i have always charged in an attached garage. this morning was 15f outside, and 42f in the garage.
    you do have an advantage with battery conditioning though, pip does not have that. is it turned on?
  12. bisco
    52,816
    and if you're using any heat, that really eats up the battery
    check your tires pressure as well, they drop with the cold
  13. Blauer Glimmer
    448
    169
    NY (Southern Tier)
    I had an 09 Prius and can attest to the dramatic drop in mpg from warm to cold - it was shocking!
    I have not tried the conditioning. The car has been finishing its charging a full hour prior to the scheduled time - will conditioning still only happen just in time for departure?
  14. bisco
    52,816
    if you are using departure time setting, i can only assume that it will. but a check of the manual, or test on a day when you don't have to leave would be a good idea.
  15. Blauer Glimmer
    448
    169
    NY (Southern Tier)
    I have been quite miserly with heat - only using it to defog when necessary by directing heat to feet & windhield, not using the defroster. I use the seat & steering wheel heaters, since they are less of a draw. I know my snow tires take a toll as well, and I keep them well-inflated. I would think all those factors show up in miles/kWh.
    Your 30% figure makes me feel a bit better - that’s about my experience right now. Wondering how much more this will drop, since we ain’t seen nothin’ yet in my neck of the woods.
    #135 Blauer Glimmer, Dec 9, 2018
  16. Blauer Glimmer
    448
    169
    NY (Southern Tier)
    I've tried conditioning for the past few days. It adds about 15 minutes to the time, so now it's done charging about 45 minutes before departure. The conditioning appears to happen at the end of the charge cycle, even if it is early. I used my app to turn on the heat in the car 10 minutes prior to departure, but this drained a bit out of the battery, so the car started charging again since it was prior to the departure time. Because I had to leave, I wound up with less estimated miles.
    I think I will just ignore the poorer EV range until the spring thaw (sometime in May 'round here). If it's still substantially reduced from last year, I will be more concerned - not that there's anything Toyota will do about it. In the meantime, I will just switch to HV mode on the highway, enjoy some heat in the cabin, and reserve the EV miles for the city portions of my commute. Even with the reduced range and the typical winter hit on mpg, I am way ahead of where I was with my 2009 Prius Touring, which struggled to achieve 40 mpg in the winter months.
  17. bisco
    52,816
    oh, that's way too sensible!:p
  18. Blauer Glimmer
    448
    169
    NY (Southern Tier)
    Let’s see if I can stick to the plan
  19. PiPLosAngeles
    1,551
    724
    On the other hand, I forgo the cabin comfort and drive to work in the cold. I just alternate sitting on my hands to keep them warm (can't find my gloves). It's kinda funny when I get to work, where it's 15 - 20 degrees warmer. The inside of my car is still the temperature it was when I left the house so it feel like opening a refrigerator.
  20. Blauer Glimmer
    448
    169
    NY (Southern Tier)
    Heated steering wheel - never thought I’d use it, but it’s perfect for those days when you realize you left your gloves at work
