no keys to 2013 prius v
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by jtuchol, Nov 13, 2013.
  1. jtuchol
    jtuchol Member
    141
    whitehouse,ohio 43571
    just bought another prius, 2013 v from co-part out of lansing, mich, and of course the keys are gone! stolden at co-part or tow truck driver took them! I own other priuses but this is the first one of these newer versions that I have ever owned there is no slot for the key that I can find. what's next? ( I know it's going to cost money)
  2. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    I assume you can't start it or drive it, correct, then I would take the vin number along with your sales papers to your nearest Toyota dealer and expect to spend the better part of $500 for two new keys. Yes there is no slot on the gen 3's, it you have a low battery in your key you can put it next to the power button and it will start. Good luck!
  3. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Connecting the dots on two recent threads, I sense the latest dealership scam -- smart cars without keys -- pay the man to replace.
  4. Stevie
    Stevie Junior Member
    95
    22
    Melbourne,Victoria,Australia
    may need to tow the car to the dealership so they can then programme the smart key to the car, worst case scenario in older models, with no working key present you would need to replace all locks and the body control module (approx. $1600 in Australia)
  5. ETC(SS)
    7,567
    I think that I would contact several locksmiths first.
    It is possible to re-program a used fob that you can get from eBay for < $20 if you've got the time to spend.
    Otherwise?
    Yeah.
    It's gonna cost you money.
    Sorry!
  6. Mike500
    Mike500 Senior Member
    2,593
    767
    If you can find the original dealer who sold the car, they might had kept one of the original "key code" tags. They a Toyota dealer can cut you tow new keys and program new smart keys for you. I know that my dealer kept one of the key code tags for my car.
    Expensive, but you'll know that it has been done right.
  7. mikefocke
    4,080
    1,862
    Sanford, NC
    A car with no keys, I'd place the burden on the car seller if they arranged delivery.
  8. Air_Boss
    4,259
    1,197
    New Yawk
    BINGO. And the burden on the delivery agent if the keys were transferred with the car.
  9. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Several "Pop a Lock" locksmiths have been able to program used keyfobs. I'd try to find one locally and explain that you have a "all keys lost" situation with a Gen3 Prius.
  10. Kensterfly
    Kensterfly Junior Member
    95
    2013 Prius v wagon
    Wondering if the OP was for real. He didn't say he didn't have the FOB, only that he didn't have a 'key.' Then he mentioned that there was not a 'key slot' in which to insert the 'key,' as if he was looking for a keyed ignition switch.
    Either he had no clue about the push button starter and didn't realize it would start as long as he had the FOB (with a good battery) OR he is pulling our leg.
    I see that he has not come back after his original post.
  11. Air_Boss
    4,259
    1,197
    New Yawk
    A distinction without a difference on these cars, the fob being understood to be the "key" that enables the "start button", so I'm not sure. That the OP appears to have been unable to start the car is the issue.
  12. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The "key slot" is a reference to the slot that was in the his older Gen II Prius. That slot is also where the sensor is located if you have a dead battery in the Fob.
  13. Alan Claver
    Alan Claver Junior Member
    79
    Central Pennsylvania
    And in Gen III Prius that sensor is in the Power Button itself. That's why you touch the fob to the power button when the battery is dead in the smart key fob - it reads the ID tag passively.
  14. Air_Boss
    4,259
    1,197
    New Yawk
    Back to the OP, my interpretation is there were no fobs delivered with the car, which means the dealer or the delivery agent should be on the hook. Unless it was winched on, a fob was required to load the car. If it had to be winched on, it's on the dealer; if not, it's on the delivery agent.
  15. jtuchol
    jtuchol Member
    141
    well I am on the hook for the keys now, I will file a complaint with co-part later, I just got keys made I bought 2 new smart keys through Toyota and had to pay for a code for the lock smith could enable the car to start. it works good on both keys now $700 dollars later!
  16. Air_Boss
    4,259
    1,197
    New Yawk
    Ouch. Please report back on outcome with Co-Part.
  17. jtuchol
    jtuchol Member
    141
    ok, not going to get my hopes up, this is second car I bought from them and same thing they sell car with keys and POOF! there gone nobody knows what happen to them and everybody plays stupid ( I think there playing) driver, co-part personal just don't care not there problem anymore!
  18. Air_Boss
    4,259
    1,197
    New Yawk
    Same SCAM happened TWICE? Call in the authorities.
  19. mikefocke
    4,080
    1,862
    Sanford, NC
    I wonder if these cars have been repossessed? Tow truck lifts it up on fork lift and plops it onto flatbed truck. Ever see the title?
    I'd start with a TV station that has a consumer fraud segment and wants a scam to publicize.
  20. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    You've been Licked by Lizard lick towing :(
