No lights flashing when unlocking/locking - but does beep
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by drahgonfyre, Apr 11, 2017.
  1. drahgonfyre
    drahgonfyre New Member
    South San Francisco
    Hello! First time poster here.
    I just bought a used 2016 Prius III and when using the keyfob to lock or unlock my car, it will beep but the lights won't flash. Does anyone know if there is something I can to fix that or is this something that I need to take back to my dealer for?
    Thank you!
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Have you tried the other FOB? It might be a battery. The Manual refers to it as a KEY if you are searching for information, which includes the following:
  3. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    Check the vehicle settings menu in the touch screen, I'd not there I think it can be set using Carista or by a Toyota dealer.
    kithmo likes this.
  4. drahgonfyre
    South San Francisco
    Thanks! Do you know where I should look in the vehicle settings menu? I've checked the manual and can't find the exact section (sorry - Newbie!).
    And the key fobs are brand new so I don't think the battery is the issue. :) I've tried both and neither flash the lights.
  5. alanclarkeau
    7,045
    7,593
    You said that the car is used, but the FOBs are new - are they genuine TOYOTA parts? Maybe when supplying NEW FOBs they haven't programmed them.
  6. drahgonfyre
    South San Francisco
    Gosh I hope so since they were supplied by the dealer. One, they claimed, was the original and the other they programmed because they lost one of the fobs. (n)
    RCO and alanclarkeau like this.
  7. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    The Carista module and app allows you to program not only the beep and light flashing, but a bunch of other things. The dealer can do this as well.
    Once I entered mine, the App emailed me a list of my selected settings. Here are the ones for my remote (most, but not all are the same as the default settings).
    1. Doors / Windows / Remote
      Blink turn signals when locking/unlocking with remote
      *YES* / NO
      Beep when locking/unlocking with remote
      *YES* / NO
      Volume of beep when locking/unocking with remote
      OFF / 1 / 2 / 3 / *4* / 5 / 6 / MAX
      Beep when opening/closing windows with remote
      *YES* / NO
      Warn when door can't be locked with remote because it's open
      *YES* / NO
      Warn when a window is still open when locking doors
      *YES* / NO
      Warn when sunroof is still open when locking doors
      *YES* / NO
      Panic function on remote
      *ENABLED* / DISABLED
      Re-lock doors automatically if you unlock, but don't open a door
      *YES* / NO
      Re-lock doors automatically if you unlock, but don't open a door within…
      30 SECONDS / *60 SECONDS* / 120 SECONDS
      Unlock doors via remote
      *DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
      Unlock doors via physical key
      Unlock doors via smart key (door handle button)
      DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
      Auto-lock all doors
      DISABLED / *WHEN SHIFTING INTO GEAR* / WHEN VEHICLE STARTS MOVING
      Auto-unlock all doors
      DISABLED / WHEN SHIFTING INTO PARK (P) / *WHEN DRIVER'S DOOR IS OPENED*
      After locking with smart key, allow re-opening within…
      0.5 SECONDS / 1.5 SECONDS / *2.5 SECONDS* / 5 SECONDS
      Smart key location to start car
      *FRONT SEATS* / ANYWHERE IN VEHICLE
      Open trunk via smart access button
      DISABLED / DOUBLE CLICK / *LONG PRESS*
      Open windows and sunroof by holding key in door lock
      ON / *OFF*
      Close windows and sunroof by holding key in door lock
      ON / *OFF*
      Open windows and sunroof via long-press on remote
      *ON* / OFF
  8. Prodigyplace
    12,710
    11,848
    Central Virginia
    Some of those settings can be set from menus either on the small or large display. There is a customizations chart in the manual. I will try to post the relevant section later.
  9. Prodigyplace
    12,710
    11,848
    Central Virginia
    RCO likes this.
  10. Prodigyplace
    12,710
    11,848
    Central Virginia
    Welcome & enjoy your 2016 Prius.
  11. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    Does anyone know if this option is available on a non US car? I would love to have this enabled on my UK car.
    alanclarkeau likes this.
  12. drahgonfyre
    South San Francisco
    Thank you! I didn't realize that Entune had additional settings. Going in there, all I had to do was check it and voila!
    Thanks again to everyone. I really appreciate it and learned a lot. :)
    RCO likes this.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    It wasn't an option on Carista when I used it.
    RCO likes this.
  14. Harters
    335
    427
    UK
    Excel
    Ok, thanks, at least I know :(
    RCO likes this.
