No low fuel light in Prius
Discussion in 'Gen 3 Prius Main Forum' started by Darhl Ehrgott, Jul 7, 2013.
  1. hlunde
    hlunde Member
    419
    75
    The omission of the conspicuous yellow, SAE/DIN, low fuel icon is unfortunate. If you look closely, you'll notice that the fuel gauge image is prominent when full and almost absent when low. So just look for the absent fuel gauge image and you'll know you're low. The "ding" helps if you're not playing the radio or riding with your windows open. Another "what were they thinking?".
  2. Darhl Ehrgott
    Darhl Ehrgott Tinyhomes
    Naples, FL
    You have to almost try to crash a 777 due to the fly-by-wire safety systems. That's why initially I thought it must have been fuel starvation. All newer generation aircraft have auto-landing capability, but most pilots don't use it. I've had over 400 landings in the 777 and have only done 4 auto-lands. There was apparently an attempt to "Go Around" a few seconds before the crash, but due to the "spool-up" time of the large engines (at least a few seconds from in-flight idle to go-around power), it was too little, too late!
  3. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Pilot error both with your Prius and the 777 that crashed.
    There's no excuse for running out of fuel in a Prius, it warns and warns and warns. Carrying more fuel has no measurable effect on fuel economy. If you're that worried, loose weight! ;)
    BTW, running out of fuel is actually very hard on the car -and- there is a DTC entered in the computer. So if it fails Toyota -may- refuse warranty. It's classed as abuse.
    vday and ralleia like this.
  4. Darhl Ehrgott
    Naples, FL
    No argument here - pilot error. I just pushed it too far and was a bit curious if there was some other kind of warning. I guess that answers that. A full tank of fuel weighs about 60 pounds more than when the fuel gauge starts flashing. It's not insignificant, but weight does impact fuel economy. The one discovery I made that was beneficial is the fact that the DTE is not "empty". You can still go more than 30 miles, which could be a valuable piece of information.
    WE0H likes this.
  5. WE0H
    WE0H Senior Member
    3,247
    528
    Top the tank off a bit and the fuel remaining after the meter says empty is 100 miles of driving nice. You could install a fuel computer if you could find a transducer that can accurately record fuel flow at the low rates the Prius flows :)
    Mike
    Mobile on my SGH-i717
  6. hubmacfan
    hubmacfan Junior Member
    57
    Hattiesburg, Mississippi
    Fixed that for you.
    If you depend on an idiot light to tell you that gas is low, you might be ...
    Seriously though, there are many threads complaining about Toyota depending on idiot lights instead of using gauges. Now there's one complaining about depending on gauges and not using idiot lights. Guess you can't win either way.
    jhinsc likes this.
  7. hlunde
    hlunde Member
    419
    75
    Every other vehicle I drive -- Volvo, Audi, Nissan -- uses the yellow or orange ISO symbol for low fuel. Ford Focus and Fusion do as well. I actually don't know of a currently-manufactured vehicle that doesn't use this icon -- except Prius.
  8. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    And that was me at 16 and I borrowed my sister's 87 Oldsmobile. She will never let me forget it. I agree, gas gauge is all you need.
  9. hlunde
    hlunde Member
    419
    75
    A real gauge would be an improvement. Check VDO catalog for what a real gauge looks like.
  10. ralleia
    ralleia Active Member
    386
    137
    Omaha, Nebraska, United States
    If I remember correctly from highway engineering, mass factors into the equations of rolling resistance and grade resistance, and not at all to aerodynamic drag. I'm too tired to try to drag out my notes tonight, but it was a linear variable.
    Velocity is a far more significant factor, as it is an exponential variable in aerodynamic drag. I for one don't reduce my velocity unless there is no one behind me on the road.
    The gas is only about 6 lbs per gallon versus water at over 8 lbs per gallon. The Prius only holds on the order of 11-ish gallons anyhow.
    If OP needs specific equations about the fuel efficiency impacts of carrying around a safety margin of 12 lbs of fuel in the tank, then I will dig out my notes later this week.
    But I hope that the common sense of protecting a $25K+ piece of property AND ones life will render the exercise unnecessary!
  11. VicVinegar
    VicVinegar Member
    275
    53
    Northern Virginia
    In the nearly 8 years since I stopped being an impoverished college student, I think I saw the "gas light" in my Civic maybe 5 times. It gets near "E", and I look for a gas station. For day to day commuting, I drive roughly 85 miles a day and knew I had to fuel up every 3 days. Especially with the constant threat of a 15 minute drive turning into an hour in DC area gridlock, it was never good to be running on fumes. With the new Prius, I'll have to figure out my new routine, but it won't involve running the gauge down to nothing.
    WE0H likes this.
  12. hubmacfan
    57
    I'm not saying it shouldn't have the idiot light or that it's not strange that it doesn't. My personal opinion is that it is stupid to ignore the fuel gauge and depend instead on the idiot light (in the absence of evidence that the gauge is not working).
  13. WE0H
    WE0H Senior Member
    3,247
    528
    Someone could design a low fuel indicator kit. Maybe there is a signal on the CAN bus to trigger a indicator?
    Mike
  14. Nora
    Nora Member
    128
    44
    CO
    Ah, a back in the day story. :) This is my second car with low-fuel warning. My Subaru had a low fuel light, but the light stopped working. That is very bad for a girl who is prone to running out of gas (hey, some people don't, some people do, and this is why I belong to AAA).
    Me: "The low-fuel light is not working."
    Ex: "Oh. Wait, how would you know that?"
    Me: "Well..."
  15. ralleia
    386
    137
    Better yet--have the car send a text to the owner's cell phone...
    Baseballkurt likes this.
  16. bathala
    bathala Member
    128
    30
    Area 52
    Irregardless of whether there's a symbol or a gauge to show low fuel, if the intention is to "I was simply pushing the limit and got caught "with my pants down" (post #4), the low fuel indicator will be ignored.
    ralleia likes this.
  17. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Amazing - when I'm driving my Prius, I'm not looking for gauges or indicators that are in my other vehicle or any vehicle I've owned in the past, and likewise when driving another vehicle I'm not looking for gauges and indicators found in my Prius. I use what I've got in front of me. What a concept.:rolleyes: The flashing pip IS the low fuel indicator for the Prius.
  18. hlunde
    hlunde Member
    419
    75
    Agree.
  19. El Dobro
    El Dobro A Member
    7,093
    3,271
    Not for nothing, the the warning light is right next to the speedometer.
  20. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Better yet, text the driver's significant other.
    Baseballkurt and ralleia like this.
