No More 999.9MPG! (For a while)
Discussion in 'Prime Main Forum (2017-2022)' started by mr88cet, May 26, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Why Toyota changed to MPG reading on the car to max out at 199.9 is beyond me ( even though it goes up to 999.9 MPG you just can't see it)
  2. ArcPrime
    ArcPrime Active Member
    201
    166
    Arcadia, California
    It's Japanese thinking. May be 1st digit can only display 0 or 1 .:D:D:D
  3. priuscatprimeguy
    2,730
    2,640
    ok, well then explain why the 2012-2015 PIP displays 999.9 MPG?:eek:
    ArcPrime likes this.
  4. ArcPrime
    201
    166
    Arcadia, California
    Cost saving thingy.:D(y)
    priuscatprimeguy likes this.
  5. Prodigyplace
    12,715
    11,848
    Central Virginia
    Interesting.
    Before Gen 4 the other members of the Prius family maxed out at 99.9.
    The Gen 4 goes to 199.9. The instantaneous mpg bar graph beside the speed maxes out at 100 still though.
    Son of Gloin likes this.
  6. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Study of the market revealed an issue with diminishing returns.
    Customer understanding of the system overall showed little value reporting numbers higher than 200 MPG.
    Most people have no clue how the electricity & gas interplay. That's why Toyota only shows one electric motor on the display, even though there are actually two.
  7. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Reporting mpg while consuming any energy besides that derived from gasoline is kinda stupid anyway.
  8. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    Did the poor response to the accelerator in HV mode continue after the initial warm up period? In my experience as others have mentioned in other threads, Prime draws power primarily from the traction battery during the warm up period. However, when you run out of EV in Eco mode, Prime seems to drop the performance/responsiveness to accelerator while drawing from the HV portion of the traction battery during the warm up period. I feel the response to the accelerator improves when it is out of the warm up period.
  9. ArcPrime
    201
    166
    Arcadia, California
    That's true. However number looks more impressive. It's marketing thing.
  10. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Ideally it would report both MPG and MPKWH.
    iPhone ? Pro
  11. mr88cet
    2,313
    1,335
    Austin, TX
    Reasonable question.
    I can't immediately recall how much it improved with warm-up. Power-split hybrids inherently have a little lag since it takes a little time for the engine to ramp up, MG1 to generate enough juice to MG2, and MG2 or negate the inertia of the car.
    In some ways that's not a bad thing, in that it gives a nice smooth start up, but it does represent lag though.
    iPhone ? Pro
  12. mr88cet
    2,313
    1,335
    Austin, TX
    I noticed two (related) interesting differences between HV on our new P.Prime and our 2009 (Gen-2):
    First, generally when the P.Prime's engine was on, it rarely got better than 50MPG. On our gen-2, I often see considerably better than that.
    Buuuuuut...
    Second, the P.Prime's engine would turn off completely considerably more often than the gen-2'so. Obviously completely off is a lot better than being on and getting high MPG!
    That's of course possible in large part to the (MG1) speed-reduction planetary-gear not present on gen-1 or gen-2. That's a big part of why the P.Prime can go up to 84MPH on EV.
  13. mr88cet
    2,313
    1,335
    Austin, TX
    The P.Prime's license plates came in, so I had to pick them up, swap them with the vanity plate "EADGBE" previously on the 2009, and then get a toll tag for the P.Prime (swapping their plate-number records too).
    Anyway, that took more than 30-some-odd miles, so I had to burn a little gas.
    911 miles, and the original fill-up is still about 80% full! Trying to remember: 11-gallon tank, is it?
    Sometime in the next few weeks, I'll probably take it down to Houston to show it off to my mom and sister -- a ~375mile round trip. That'll burn that tank down a bit, but still have a fair amount left!
    After I burn down that tank, I'll probably plan on going to the gas station once every 6 weeks or so, putting in 5ish gallons each time. That is, unless I take a road trip, of course.
    iPad ? Pro
  14. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    The tank is stated at 11.3 gal. and when my miles to empty went to 7 miles left, I filled up with 10.35 gallons, no topping, first click.
    #34 Prius from Dad, Jun 1, 2017
